XJ40 ( XJ81 ) 1986 - 1994
Urgently. need help with car parts
Old May 27, 2017 | 03:55 PM
lenavarrete's Avatar
Default Urgently. need help with car parts
I have a Jaguar XJ6 sovereign 1990 and am at a car junkyard and found a jaguar xj6 1996
i need a fender, hood, front defense and radiator, frot lights roght and left
can i use any of the parts from the 96 for my car?
also, i found a 1993 xj6 too...
Old May 27, 2017 | 04:08 PM
I found a 1993 jaguar xj6 too.
Old May 27, 2017 | 04:47 PM
Lawrence's Avatar
You can use all of the body parts, lights, bumper and hood from the 93 - not sure about the radiator, it may be different on a 90.
You can't use any parts from the 96.
Larry
Old May 29, 2017 | 11:55 PM
Don B's Avatar
That's not strictly true.... There are various parts from a '96 that may fit a '90, such as the wheels, certain suspension parts (front spring pans, spring packers, upper ball joints), the differential and halfshafts, the thermostat cover, possibly the engine coolant temperature sensor, the cruise control actuator, the windshield wiper arm, parts of the J-gate, and other bits and pieces. But it would take a lot of research to figure out what to grab off of the '96. The '93 is a much better bet!
Cheers,
Don
Old Jun 1, 2017 | 03:31 PM
Thank you, so I grabbed the parts (except the radiator) and I will post here when they are ready
Old Jun 1, 2017 | 07:58 PM
Don B's Avatar
I should have mentioned earlier that if the interior color of the '96 is the same as your car, you should grab the cupholder/arm rest, which will fit your '90 just fine.
Cheers,
Don
Old Jun 2, 2017 | 12:20 AM
Lawrence's Avatar
For sure Don, but our OP was only looking for
so of course none of these bits from the '96 would fit!
Larry
Old Jun 2, 2017 | 12:05 PM
Don B's Avatar
Hi Larry,
I interpreted the OP's question, "....can i use any of the parts from the 96 for my car?" to be more general, beyond his immediate needs.
I also interpreted your response, "You can't use any parts from the 96," to be a general statement to the effect that nothing on the '96 would fit a '90.
Communication is a funny thing, especially when it's based entirely on text with no human visual or vocal cues!
Cheers,
Don
