XJ40 ( XJ81 ) 1986 - 1994
very slow on take off.
Old Jul 23, 2008 | 04:57 PM
Keith's Avatar
Default RE: very slow on take off.
You might want to check the fuel filters in the tanks, may need cleaning as well.
Old Jul 26, 2008 | 07:24 PM
Keith's Avatar
They'll be a filter in each tank. Drain the tanks, then, there are two drain plugs, one inside the other. The smaller is for draining. The larger, basically a large nut, is for accessing the filter. You'll see the filter, and just pull it out. These tanks are nortorious for collecting water, as well as all kinds of crud. Draining a little off should be a regular ritual, maybe every 6 months or so. I'd have a new rubber gasket for the drain plug. Cheap, and available at any Jaguar parts house, or dealer.
Old Jul 29, 2008 | 10:31 PM
Keith's Avatar
OK, yours may be different, just find the drain on the tank, and I'd bet theres a filter just inside the drain plug. Gotta love these cars, not all the same. Some of the differences come from running out of parts in mid year, and the factory using whatever was available.
Old Jul 30, 2008 | 06:35 AM
Keith's Avatar
My apolizies, I could have sworn I read you had a 87, instead of an 88. Of course there is a difference. My imput would have been OK with the series III, but may not be with your 88. I guess age is taking its toll on my eyesite. Couldn't hurt though, to make sure theres no crud gathering in the tank, blocking the intake lines.
jimforrest (uk)
Feb 28, 2019 06:42 PM
Seth
Nov 1, 2015 12:17 PM
MrWhite
33
Oct 22, 2015 10:29 AM
Swagguar
Sep 30, 2015 01:34 PM
JTC3400
Sep 29, 2015 05:03 PM
