XJ40 ( XJ81 ) 1986 - 1994
vin NUMBER ERROR
Old Jul 19, 2020 | 03:42 AM
Rodoz's Avatar
Default vin NUMBER ERROR
Hello All, I am just inquiring if anyone has found their Jaguar VIN number does not match the details on the under hood compliance plate and under windscreen. Mine is a 1993 XJ40 4.0 SAJJHALD3AT659956 When decoded it comes up as 2010 with decode error. Did Jaguar get the VIN system wrong ? This vehicle has not been re manufactured.
I would be interested to hear if they got the VIN system wrong or has the VIN number system changed ?
Stay COVID19 Safe, Regards from Rodoz
Old Jul 19, 2020 | 08:23 AM
Doug's Avatar
Almost certainly nothing to be concerned over.
Over the years the world has seen a few different VIN formats.
There are lots of VIN decoders out there, many of them programmed to decode USA/North American formatted VIN numbers. You've probably stumbled onto one of those.
Try some different decoders. Or someone here with a factory service manual will come along and decode it for you
Old Jul 19, 2020 | 10:54 AM
It decodes correctly with the Jaguar decode table from JEPC (Jaguar Electronic Parts Catalogue) apart from the Emission Control System:
However, the full VIN does return invalid in the Jaguar Dealer TOPIx system:
I wouldn't worry too much about it unless you are concerned the vehicle has been cloned.
Last edited by GGG; Jul 21, 2020 at 05:36 AM. Reason: Remove my full name from TOPIx graphic!
Old Jul 19, 2020 | 09:56 PM
Rodoz's Avatar
Thank you Graham and Doug for your response and information. I dobt the vehicle has been cloned . None of the dozens of Vin decoders I tried , were able to fully decode SAJJHALD3AT659956. All of them returned a Vin number error message. Even on Grahams table it does not accurately define the year. The chassis build tag indicates 92 and compliance plate 03/93 when vehicle was completed. Were the first XJ40's 92 ? I dont know.
Anyway time will tell, thanks for your contributions.
Regards Rodoz
Old Jul 19, 2020 | 10:59 PM
Doug's Avatar
Regards Rodoz
The earliest production XJ40s were built late in calendar year 1986; considered 1987 "model year" by most. But, model year designations can get a little weird with cars sold worldwide, as different countries/markets have different ways of treating/interpreting that designation.
Old Jul 20, 2020 | 08:55 AM
jerry_hoback's Avatar
My Xjs has a different vin stamped into the top of the cowl than the one in the window (and everywhere else on the car.) If I recall, there was a thread about that describing who used it and why. Try searching the xjs section, although I honestly dont remember where I read that.
Sorry, I just had to muddy the water.......
Old Jul 20, 2020 | 09:50 AM
Doug's Avatar
The cowl VIN is the one your XJS was born with, so to speak. On cars headed to the USA (and perhaps Canada?) Jaguar added a second VIN that meets USA requirements.
I've heard, but not confirmed, that Japan, too, has specific VIN requirements. There are probably others as well.
Old Jul 20, 2020 | 12:02 PM
Lawrence's Avatar
If your electrical plugs are big and "cylindrical" rather than small and "cuboid" you have a 92
Larry
Old Jul 20, 2020 | 08:58 PM
Rodoz's Avatar
Good morning Larry, thank you for your message,. Yes the bulk of my electrical connectors are the larger cylindrical type so mine is most likely a 92 even though the aluminium compliance plate under the hood says 03/93 . Thank you for the tip.
Regards from Rodoz
kevinamon
Dec 15, 2015 11:35 AM
roamingrichy
Dec 1, 2008 02:45 PM
