XJ40 ( XJ81 ) 1986 - 1994
Waist finisher seals
Old Feb 22, 2020 | 06:24 AM
Jona29's Avatar
Default Waist finisher seals
Hi all, I've just joined the forum today, I need to change all 4 waist finisher seals on my 1994 XJ40 Sovereign. The parts are on the way, courtesy of Ebay, can anyone tell me how to remove and refit please? Regards, Jona.
Old Feb 22, 2020 | 09:55 AM
Lawrence's Avatar
If you're referring to the chrome (stainless) trim strips they are just glued on on the 94MY.
Removal of old ones? Try using a thin guitar string like a cheese slicer, start at one end and "saw" your way along.
Larry
Old Feb 27, 2020 | 04:17 AM
Brake buster's Avatar
i believe he is referring to the window seals on the chrome trim under the side windows,
if this is the case its fairly easy , on the back its a simple gently pry up and remove , but be gentle as you dont want to scratch paint or damage the trim if reusing
the front doors are a different matter, the door mirrors need removing as these trap the trims before you can pull them up , winding down the windows does help with refitting ,
i presume yours have ' blown ' rubber due to corrosion to the aluminium reinforcement inside the trim , a smear of grease to the exposed aluminium will help prevent this corrosion before you fit them
good luck
BB
Old Feb 29, 2020 | 05:17 AM
Jona29's Avatar
Hi, BB and Larry, thanks for your replys. Yes, the rubber on the O/S/R has severely warped and is not even touching the window, the others are not as bad, but are showing signs of distortion. I've recieved the replacements, and hope to start renewing the old ones at the next available opportunity, thanks for your guidance.
Regards,
Jona.
dpoznan
E type ( XK-E )
Jul 9, 2018 09:38 AM
ultrablu
May 9, 2015 10:23 PM
jaguar jon02
E type ( XK-E )
Oct 22, 2014 11:35 AM
michael prichard
XJ40 ( XJ81 )
Apr 6, 2014 03:46 AM
mickvic
XJ40 ( XJ81 )
Mar 26, 2014 11:08 AM
