XJ40 ( XJ81 ) 1986 - 1994
Weird surging idle after battery change
Old May 2, 2019 | 01:27 AM
Sarc's Avatar
Default Weird surging idle after battery change
On my 45k mile 1990 US spec XJ40 4.0
We changed the battery and the oil and filter. First few starts and idles it was fine. Then it starts with this nonsense.
Car was for sale and is actually now sold...... on its way to new owner on Friday, so would be kind of handy if it ran properly by then.
It behaves like a vacuum leak, but the fact that it can sometimes just go away on its own, or sometimes goes away after a restart makes me think its not a vacuum leak, more like an electrical ECU type issue after the battery change.
I've changed the battery before and didn't do anything special to recover it (apart from retraining the alarm remotes) and I never came across this issue until now. Maybe I was "lucky" previously.
No Check Engine light. No codes in the VCM.
Old May 2, 2019 | 09:22 AM
Sarc's Avatar
Resetting by disconnecting the battery cables and shorting them out, then starting from cold and waiting for warm up then driving made it slightly better.
When it is bouncing around if I shift it into drive that pulls the idle down then back in to park and it's fine.
So I have an idle problem, not a vacuum problem. My gut feel is if I just drive the thing for a while it'll short itself out, but that's not a great story for the excited new owner.
Next thought is to clean the throttle body and intake manifold........
Any other inputs welcome at this point
Old May 2, 2019 | 10:22 AM
Lawrence's Avatar
This is a possible fix ....
Take it for a drive - the ECU has to re-learn all the settings after a "big" disconnect and you need to take it out get it warm, do some town and highway driving, maybe 5 or 10 miles and then it should be ok ...
Larry
Old May 2, 2019 | 10:53 AM
Sarc's Avatar
Hi Larry
Thanks for the suggestion. Now that the red mist has settled and I'm thinking a bit straighter, I have had the same behavior before, albeit on other Jag models. And in those cases just driving it fixed it.
Will go put some miles on it today and see what happens
Scott
Old May 2, 2019 | 10:57 AM
nunger1330's Avatar
Check the connection at your IAC motor. It will relearn where the piston can be but it should go away relatively quick. Seems like you may have a spotty connection if it is intermittent. Did you wash the engine compartment or anything like that since you are trying to sell it?
Old May 2, 2019 | 11:13 AM
Sarc's Avatar
Nope, no engine bay washing.
To add more detail to my second post, and also to bolster Larrys idea, I only drove the car about 300 yards after doing the reset........ I'm thinking this is not enough so will go drive it more.
But, I will check the connector and clean it anyway. We were changing oil, swinging batteries in and out, etc so there's always a chance of something getting knocked
Old May 2, 2019 | 10:20 PM
Sarc's Avatar
So..... We did a lot of driving with the car today and all appeared well, but then after sitting for 3 hours, at restart the idle bouncing returned.
After a few key off and ons, everything returned to normal.
I inspected and cleaned the IAC connector. All looks ok.
Puzzled.......
Old May 3, 2019 | 02:00 AM
nunger1330's Avatar
When it runs normal, if you disconnect the stepper motor is that the symptom you see?
Old May 3, 2019 | 02:25 AM
Lawrence's Avatar
Have a read of this thread Sarc, stepper motor setups for the different motors
https://www.jaguarforums.com/forum/x...e-idle-118636/
Larry
Old May 3, 2019 | 04:59 PM
jerry_hoback's Avatar
I had a surge and found the check valve on the evap canister was broken in half. A constant 3/8 leak...... maybe yours?
Old May 3, 2019 | 05:48 PM
Sarc's Avatar
To close the thread, I left the battery cables connected together for 30 minutes, then drove it 20 miles and all good.
She's off too her new owner.
Thanks for the help. Down to 2 Jags........ Gosh
Old Oct 27, 2019 | 12:56 PM
Mike shea's Avatar
Sarc when you say you left the battery cables connected together is the battery completely disconnected at this point and you just connected the positive and negative cables together?
Old Oct 27, 2019 | 02:51 PM
Lawrence's Avatar
This is called a hard reset, you just have to undo the neg terminal and hold it to the positive cable. The positive terminal doesn't have to be disconnected from the battery as the battery is out of the circuit with the neg terminal off.
The idea is to drain the capacitors in the ecu of any residual charge that could prevent the ecu from forgetting some settings that you *might* want to erase.
Larry
Old Oct 27, 2019 | 03:46 PM
Mike shea's Avatar
Larry
Larry thank you for your detailed instructions on the hard reset I’ve looked everywhere on here for that information but I was only able to find half assed partial instructions I am trying everything I can think of to fix my surging idle on my 5.0 XF
Old Oct 27, 2019 | 05:35 PM
Lawrence's Avatar
Hi Mike, this info is just for pre OBD11 cars, like the XJ40. The XF is way newer and I have no idea how that ECU works, take my info with several grains of salt please or better still ask in the XF forum!
Larry
Old Oct 28, 2019 | 07:30 PM
Brewtech's Avatar
Hard resets work on my 2007 XK, so it works on obd2
Old Oct 28, 2019 | 09:55 PM
Don B's Avatar
Hi Mike,
I replied with a few ideas in your thread at the XF forum.
Cheers,
Don
Ktmscott
Sep 14, 2019 05:44 PM
thor411
16
Jan 26, 2017 10:25 PM
Daim
Jan 27, 2016 06:23 AM
John-Melanie
Dec 2, 2011 12:56 PM
Tantalus
Mar 7, 2011 11:16 PM
