XJ40 ( XJ81 ) 1986 - 1994
What is this button for?
Old May 24, 2011 | 09:40 PM
stunnin's Avatar
Default What is this button for?
Button located under the gear shift with "S N X" which denote 3 different positions. Dash lights up "Sport" when you push "S". Dash lights up "X" when "X" is pushed and nothing happens with the "N" that I am noticing. I assume the "S" will increase the rpm. However, I have no idea about the other two.
Appreciate any help.
Old May 24, 2011 | 09:42 PM
stunnin's Avatar
sorry...forgot to mention this is a 1994 XJ6
Old May 25, 2011 | 03:10 AM
hefeweize's Avatar
Im interested as well. What is the N X for? haha. im sure its in the user manual tho
Old May 25, 2011 | 04:06 AM
Cadillac's Avatar
Those are tranny shifting modes
N should be nornal , fuel efficient way of driving your car , shifts are lower RPMs
S refers to Sport Mode, exact driving pleasure and shifts up at higher RPMs , your car accelerates faster with this mode chosen
I have no idea what X refers to , sorry . I have 1/2 on my ride , it's for using in winter mode
Old May 25, 2011 | 05:15 AM
Try pressing the X when you have an unwanted passenger aboard.
Don't forget, pics are a must.
Old May 25, 2011 | 07:50 AM
Kirk511's Avatar
The X position of the switch locks out first gear. If you look at it closely you'll notice that it is an X over a 1.
Old May 25, 2011 | 09:09 AM
stunnin's Avatar
Thank you! Ha ha...I almost put that it was a 1 with an X through it. So what would be the reason to use this?
Old May 25, 2011 | 10:04 AM
Doug's Avatar
To reduce the chance of wheelspin on slippery surfaces and/or a more leisurely, stately, take-off from a stop.
Old May 25, 2011 | 10:08 PM
stunnin's Avatar
LOl...I think it only works when I wear my superhero disguise.
Thanks for pointing me in the right direction.
Old May 25, 2011 | 10:23 PM
Kirk511's Avatar
I checked the switch when I got in the car and it is actually a 1 with a / thru it, rather then an X. Low wheel spin in slippery situations i.e. snow and ice or drag racing are few of the reasons to use it. Not that I'm suggesting you should be drag racing your XJ40.
PolkNole
Oct 21, 2025 02:22 PM
ricwel
Jun 23, 2023 05:14 PM
philwarner
28
Jul 11, 2017 10:21 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
apolloxk8
Sep 28, 2015 08:27 PM
