XJ40 ( XJ81 ) 1986 - 1994
Where should this drain to?
Old Aug 10, 2019 | 09:38 PM
Brewtech's Avatar
Default Where should this drain to?
Ive been using my AC more this summer, and just discovered that the drivers side has been getting wet. I pulled the carpeting and discovered that this spout is leaking right into the cabin. Where should it be draining to? Its literally just dangling there.
The plastic tube is draining condensation directly in the drivers side
Old Aug 11, 2019 | 12:54 AM
Lawrence's Avatar
That tube joins to another tube (behind the carpet) and drains out of the floor, next to the tranny. Lift the carpet and/or check the passenger's side to see the way it's routed - passenger side is identical.
Larry
Old Aug 11, 2019 | 10:55 AM
Brewtech's Avatar
Thanks Larry. There is some insulation that I hadn't pulled off. Ill get to the bottom of it!
Pattie
Mar 18, 2018 06:44 PM
BKSinAZ
Mar 9, 2015 04:09 PM
navcanman
Sep 5, 2011 10:40 AM
