XJ40 ( XJ81 ) 1986 - 1994
XJ40, 1994 - "clunk" when reversing
Old Nov 24, 2015 | 07:26 PM
dstjohn's Avatar
Default XJ40, 1994 - "clunk" when reversing
Hello, My Jaguar has about 150k on the clock, now when reverse is engaged there's a "clunk" as the car moves back!
Any suggestions would be appreciated, David
Old Nov 24, 2015 | 09:28 PM
Well, a few things come to mind.
1) Rubber drive coupling on the pinion flange of the diff is past its use by date.
2) If NO rubber coupling, the 4 bolts that hold the pinion flange TO the prop shaft flange are loose. Seen that many times.
3) Idle is too high, and the system is "winding up" too fast.
4) Halfshaft uni joints need a good greasing. Probably not been done since 1994. If they are too bad, new uni joints will be needed.
5) Transmission mounting needs attention.
A quicky repost in the XJ40 section will get you many more suggestions, I am sure.
Old Nov 25, 2015 | 02:01 AM
David,
I've moved your question from General Tech Help to XJ40 forum. This is the place to post tech questions about your model.
Old Nov 26, 2015 | 10:12 AM
dstjohn's Avatar
Thanks, I think you've covered it all.
kapows
UK & Eire
Mar 2, 2016 01:10 PM
ericjansen
XJ40 ( XJ81 )
Jan 26, 2016 02:15 AM
X Type 2003
Dec 3, 2015 11:18 AM
X Type 2003
Nov 27, 2015 07:52 AM
kapows
Nov 25, 2015 01:25 AM
