XJ40 ( XJ81 ) 1986 - 1994
XJ40 2.9 conversion to 3.2
Old Jun 12, 2023 | 08:43 AM
Herschel's Avatar
Default XJ40 2.9 conversion to 3.2
I am from Sri Lanka and have a XJ40 1990, 2.9. Engine is damaged beyond repairs. I want to put a 3.2 engine and what things I need to change.
Old Jun 12, 2023 | 10:45 PM
Scd's Avatar
Scd
Hi, will need the 3.2 ECU and possibly the wiring loom, and the donor engine must come with the exhaust manifold and if not the same transmission (ie manual donor to auto and vice versa) you will need to swop over the transmission adapter plate.
You will also need the inlet manifold complete with air intake plus the injectors, basically you need the donor engine to be complete!
From memory I think the exhaust down pipe is the same along with the ignition coil and amplifier and as the blocks are virtually identical it will drop straight in. Good luck.
Old Jun 13, 2023 | 01:41 AM
Herschel's Avatar
Hi,
Thanks for the info.
Jean-Paul
XJ40 ( XJ81 )
Aug 28, 2022 04:30 PM
Putter03?
XJ40 ( XJ81 )
Jul 21, 2021 05:34 PM
Geoffh
Jun 28, 2021 01:12 PM
retromotors
Non-Jaguar Vehicles
113
Mar 22, 2011 07:54 PM
