XJ40 ( XJ81 ) 1986 - 1994
XJ40 drivers door
Old May 8, 2023 | 09:39 AM
taperguy's Avatar
Default XJ40 drivers door
Hello Forum. I have a 1988/89 Jaguar sedan. The outer door handle broke several years ago and was replaced with a remanufactured one as the lever had broken. The car door was shut recently and now it can'r be opened from inside or outside. It seems that the auto lock function has deployed. There are 2 places where the wires all join, but I don't have any circuit diagram to help me discover which wires I might be able to connect to either lock or unlock the latch. The door is now shut and cannot be opened. I have removed the inner door trim and have access to the wires, but a wary of trying to activate the actuator to release the lock function. I have tried to power the actuator but, without any clear steps outlined am worried about doing damage by powering the wrong circuit. Does anyone have clear steps I can safely take to manually switch the actuator polarity so I can open the door? When I try to do it from inside the car, I have to get into the car via the passenger door and access the door latch using a screwdriver to move the levers on the latch, but cannot release it.
Old May 8, 2023 | 10:44 AM
Lawrence's Avatar
I believe the actual actuator has two wires only. If you unplug the pigtail, you should be able to isolate and power the switch directly. I'm not sure but I think you'd be ok even if you reversed the contacts momentarily.
Old May 8, 2023 | 02:43 PM
motorcarman's Avatar
Gus has ALL the earlier Jaguar Electrical Guides on his site.
S65_89.pdf is the guide you want
About a 6.6mb download.
Old May 8, 2023 | 05:29 PM
jerry_hoback's Avatar
The auto lock is different from "opening the door." is the door stuck in locked position, or are both handles inop?
JensenHealey
XJ40 ( XJ81 )
16
Jul 7, 2020 10:20 PM
UKcat
Dec 2, 2016 12:23 PM
ryan_border
Aug 29, 2015 11:29 PM
fourbyfourbyfar
May 8, 2012 02:16 PM
Pamiam
Nov 18, 2010 04:44 PM
