XJ40 ( XJ81 ) 1986 - 1994
XJ40 instrument cluster intermittent failure
Old Jun 25, 2019 | 05:06 PM
pixiesjag's Avatar
Default XJ40 instrument cluster intermittent failure
Does anyone have a link to the photo of the board to check and redo the solders and the procedure to get to the circuit board I found it once looking into how to fix this problem is does come back on with a whack but I know that will only work for so long.or a video or set of pictures followed with the instructions would be nice
Old Jun 27, 2019 | 06:17 PM
Don B's Avatar
Hi pixiesjag,
I don't recall anyone posting a photo tutorial, unfortunately. I posted tutorials on replacing the bulbs in our '93 cluster so it may help you get yours out. The large images at Jag-Lovers are still down but the thumbnails and descriptions are still visible:
Jaguar XJ40 Instrument Cluster - Part 1 of 2
Jaguar XJ40 Instrument Cluster - Part 2 of 2
Once you can see the circuit boards, inspect every solder joint carefully. Starved joints are obvious - they don't have enough solder. Cold joints have a dull, rough appearance. Cracked joints are not always easy to spot, but if you see a dark circle in the solder around any component pin, that's usually a crack. Check especially at the electrical connector pins and pins of any relays, displays or other "heavier" components you see. Reflow and supplement with new solder every suspect joint.
Cheers,
Don
Old Feb 23, 2023 | 10:50 PM
Porcupine's Avatar
Gophat
Feb 28, 2022 12:35 AM
OrigamiSensei
XJ40 ( XJ81 )
Nov 30, 2021 10:12 AM
wpaturzo
XJ40 ( XJ81 )
Mar 20, 2018 08:35 AM
dskul1
XJ40 ( XJ81 )
Jun 3, 2016 08:12 PM
GLH
Oct 23, 2013 07:04 AM
