XJ40 ( XJ81 ) 1986 - 1994
Headlight relay location? High beams won't stay on.
Old Feb 19, 2023 | 02:31 PM
Calab's Avatar
Question Headlight relay location? High beams won't stay on.
When I pull back on the stalk for the high beams, they light up. They go out as soon as I release the stalk. When I activate the lights, I do hear a relay clicking from the engine compartment, but I can't work the stalk and look in the engine compartment at the same time. I've read that there is a relay that latches the lights on and off. This is most likely my problem. I cannot, for the life of me, locate the headlight relay, or the under hood fuse compartment at all.
Where can this headlight relay be found? How about the general under hood fusebox - assuming that there is one.
I apologize for all of the posts I've been making. It seems that I'm jumping all over, but I am just working on the items for which I have parts and tools, as I discover issues. This car is definitely more of a head scratcher than I originally anticipated. Thanks for all the help I've received so far. Hopefully I can turn the tables and give some help later on.
Old Feb 19, 2023 | 04:22 PM
motorcarman's Avatar
The ELECTRICAL GUIDE will have ALL the relay, fuse and module locations!
Gus has them all on his site.
jagrepair.com
Old Feb 19, 2023 | 08:13 PM
Calab's Avatar
jagrepair.com
Looks like I'm out of luck then...
Electrical
Under Construction
But a good source of XJ-40 TSBs! Thanks!
Old Feb 19, 2023 | 08:28 PM
Lawrence's Avatar
Go to this page, XJ6/XJ12 most of what you need is here
JagRepair.com - Jaguar Repair Information Resource
Larry
Old Feb 20, 2023 | 01:05 PM
Calab's Avatar
Larry
Thanks... The XJ-6/XJ-40 stuff muddy the waters for me.
I wish I could find an owners manual. I hate asking silly questions like the following...
To turn on the high beams, do I push the stalk away from me, or towards me? If I pull towards me, the high beams stay on as long as I hold the stalk. The stalk will not go away from me at all, and doesn't feel like it should. Up and down are the turn signals, and pushing towards the column is the horn. The stalk won't twist either, so I can't figure out how the high beams are supposed to stay on.
Looking at the electrical diagrams, I don't see any kind of headlight relay., but I do see a right and left front bulb failure module. Sounds expensive to replace, and odd that neither would latch the high beam.
Old Feb 20, 2023 | 02:16 PM
Lawrence's Avatar
Away from the car at the moment but I think it's an impulse switch, with lights turned on, pull once = on/highbeam, pull second time = off/lowbeam and so on.
Pull with headlights switched off, high beam flash.
Larry
Old Feb 20, 2023 | 04:25 PM
S65_90.pdf
File Type: pdf
Old Feb 25, 2023 | 08:25 AM
Calab's Avatar
Thanks!
I was able to figure it out... Pull towards yourself to switch. High beams won't stay on unless the headlights are switched on. All is working as it should.
The DRLs were confusing me, as I though I had automatic headlights that came on when dark. I didn't realize they were a thing in 1990.
Now I need to find the time to pull the front end apart so I can aim these headlights properly.
LT1 jaguar
Nov 24, 2019 02:04 PM
adenshillito
May 17, 2017 09:05 AM
yarpos
Nov 9, 2016 12:34 AM
marvin1960
Apr 23, 2016 08:51 PM
dixie1351
Jun 17, 2009 01:16 PM
