XJ40 ( XJ81 ) 1986 - 1994
XJ40 oil pressure problems
Old Apr 20, 2009 | 02:19 PM
danthefitter72's Avatar
Default XJ40 oil pressure problems
My xj40's oil pressure goes into the red on tickover once its warmed up and has been running for approx 15 mins, the engine is still very quiet and smooth despite the low pressure. When driving along the pressure goes up to and past the halfway mark on the gauge. The car has covered 170k miles and has full service history (mostly jaguar), i have changed the oil and filter and nothing has changed.
Any ideas, could it be worn bearings, oil pump or could it be a faulty sender?
Any info greatfully received
Dan
Old Apr 20, 2009 | 02:24 PM
JagtechOhio's Avatar
20/50 oil for that engine, and a new sender.
Old Apr 21, 2009 | 01:56 PM
Does anyone know if an oil sender off a 3.2 is the same as the 4.0 as a friend has a spare one. Ive called a jaguar dealer and all they say is that they look the same but will not tell me part numbers etc.
Old Apr 24, 2009 | 11:18 AM
db in uk's Avatar
The two parts are the same - Jaguar list JLM20791 as "oil pressure switch and link lead" for both the 3.2 and the 4.0 litre engines. This is the later X300 part and will register the level at the middle of the dial to display that there is oil pressure in the engine - it will not display the actual oil pressure measurement like the original part.
Jaguar XJ40 part numbers are available on the JDHT website -
http://www.jaguarclassicparts.com/html/JCPHomePage.html
Unfortunately it is not an easy website to use.
Hope this helps,
David
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
ZJag
26
Sep 5, 2016 03:33 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
