1976 xjs-c 4.2
Old Aug 11, 2010 | 11:09 PM
Doug's Avatar
I thinking you have an XJ6C...like a four door XJ6 but only having two doors.
I've never worked on one so don't take what follows as gospel by any means.
It should have two pumps. If you don't see them in the boot they might actually be in the tanks.
No inertia switch that I know of.
Some had the fuel pump circuit running thru an oil pressure switch...no oil pressure, no fuel pump operation.
Don't know if the pumps were fused or not. The later F.I. models had un-fused pumps <shrug>
If you can find the pumps you can bypass the circuit with a jumper wire directly to the pump(s) from a 12v source and see what happens
Sorry I don't have anything concrete
Old Sep 18, 2010 | 08:48 PM
tsingtao35's Avatar
The pumps are immersed in the tanks and are no longer made anywhere. Best bet is to do a conversion. How? I haven't figured that out yet.
Old Sep 20, 2010 | 03:14 PM
skaterdudz02's Avatar
I would recommend taking the fuel line going to the carburetors off and turning the motor over to see if you have gas flowing.
If yes, then it could be plugged up in the carburetors.
Do you have spark?
Old Sep 21, 2010 | 07:49 PM
tsingtao35's Avatar
Get donor tanks and run SU pimps to the body.
Old Sep 22, 2010 | 11:57 AM
Fraser Mitchell's Avatar
As a carburetted car, the fuel pump supplies fuel at low pressure. AFAIK they are immersed in the tank, so if no good, you will have to find used replacements, or use an external pump. There is a tank changeover switch on the centre console, which switches electric supply to one of the two pumps, have you checked this out ?
Joachim1167
Nov 7, 2020 09:18 PM
JungleJonny
Oct 5, 2015 03:52 PM
philwarner
Oct 2, 2015 11:23 AM
kingdom worker
Oct 2, 2015 05:43 AM
