2 Jags in a row!
Old Nov 18, 2015 | 09:54 AM
Wannabeted's Avatar
Default 2 Jags in a row!
Hello All! I have a 1990 xj6 with approx. 165k on the mileage. Here's my situation. I'm going down the road after about 15 min. and I'll come to a stop light... Stop sign... And my oil pressure gauge will drop like a stone to low. I'll press the fuel pedal and I'll have some hesitation. Once the gauge moves up... The hesitation is gone. I have tried to put the 'Ol Girl into "Neutral" before giving it the gas in hopes that pressure is built and then I can be on my way with no problems.... No luck. The pressure gauge will only move up if the car is in gear. I'm stumped. I had a 1990 XJ Sovereign that did the exact same thing. Both cars had approx. the same mileage. Could someone shed some light on what the deal is with this? Thanks!
Old Nov 23, 2015 | 11:18 AM
amaezing's Avatar
sounds like an oil pump going bad.
Old Nov 23, 2015 | 12:06 PM
JagCad's Avatar
I'd try a new sensor. That one acts sluggish. I've been there.
Carl
Old Nov 23, 2015 | 12:08 PM
JagCad's Avatar
The sensors are not all that long lived. many have found that a new one or a good known used one fixes weird OP!!
Verify with amechanical guage. Always a good idea.
Carl
Old Nov 24, 2015 | 09:13 AM
Wannabeted's Avatar
Hey, Thanks a LOT! Where could I find that/those sensors? Near the oil pump itself?
Old Nov 24, 2015 | 03:47 PM
XJeej's Avatar
Mine is on the oil filter housing/next to it. My pressure gauge said 0psi with a hot engine, turns out it's 1 bar pressure.
I got a mechanical gauge at building supply store (?) it's used in boiler's, etc. but works fine with oil.
My car is a 1969 XJ6-4.2 btw
redV12
Nov 6, 2015 08:33 PM
curtizb
Nov 5, 2015 12:36 PM
harvest14
Oct 29, 2015 10:40 AM
Dale Konkol
Oct 25, 2015 11:12 AM
1990XJ6
Oct 25, 2015 05:01 AM
