3D Printer to the rescue
Old Jun 30, 2019 | 12:40 PM
neinz's Avatar
Default 3D Printer to the rescue
When I first got our XJ6C there were a few plastic interior bits that were very brittle and weathered with time. One of the items was a side vent for the center console. I know that I could have purchased one on the world wide web, but where's the fun in that? Plus I'd saving around $50. That's a decent bottle a whiskey there. So I designed one in Solidworks and 3D printed it a home. My car is far from being concourse quality, so I wasn't concerned with it being completely original. The vent angles are slightly off, but I'm fine with it.
If anyone would like the file for it, just let me know.
Old Jun 30, 2019 | 12:45 PM
Jose's Avatar
those vents are still available, I have 2 or 3 pairs of them because they crack with aging and overtightening.
However, good job reproducing them.
Old Jun 30, 2019 | 12:53 PM
muttony's Avatar
That is awesome. I have wanted to do this forever but do not know how to use Solidworks. Please post the file here because the harder the old parts get to find the more this kind of thing will come in handy. I have an idea to replace the non-functional trip computer with a 3D Printed blank with a socket for a small battery powered craft clock like this. If you feel like designing it you'd have alot of new best friends I'll bet. With sanding I understand that you can get this finish smooth.
Anyway, good work!
Old Jun 30, 2019 | 12:54 PM
muttony's Avatar
And how about those defroster vents that the pins crack off of? Try finding one of them for less than $50.00!
Old Jun 30, 2019 | 12:55 PM
neinz's Avatar
Thanks Jose!
Old Jun 30, 2019 | 01:04 PM
neinz's Avatar
Thanks muttony! The defroster vent was going to be my next project, mine are just sitting/floating in their dash openings. The clock design is very interesting. I would need some dimensions to work off of though as my 1975 does not have a trip computer.
Here are the files you requested.
File Type: zip
Old Jun 30, 2019 | 01:26 PM
muttony's Avatar
Thanks and saved. You ought to take requests, Design the part and put the file up on ebay or the forum classifieds and ell them for $5.00 a piece. Tons cheaper and easier than chasing down unobtainium plastic bits for lots of money, particularly when your local public library has a 3D printer that you can use for cost!
Old Jun 30, 2019 | 04:45 PM
Yellow series3's Avatar
Printing our own parts is fantastic. Many trip computers don't work, how about a black plastic panel that replaces the stock trip computer then we would have a nice spot to mount toggle switches, USB ports, any clock we prefer, etc etc.
I see that 3D silicone printing is coming. Then we will all be able to replace the rubber cylinder that drains the air intake grill with duckbill. Also that brown rubber cap that covers the master cylinder lid.
The future of our XJ6s looks very bright indeed.
Jeff
Old Jun 30, 2019 | 06:00 PM
muttony's Avatar
That's what I was originally thinking over a year ago. It would be dead easy to mount a switch there for the power antenna!
Old Jul 2, 2019 | 04:31 PM
I don't know if anyone got back to you regarding the dimensions of the trip computer. Fortunately, I am replacing my woodwork and have a trip computer panel apart. The trip computer fits into the panel much like our car's switches. They slide back into a rectangular hole with metal fingers holding it in place on either side and the flange or lip on the front keeps it from going on through. The outside dimensions need to be at least those shown below so the fading of the wood doesn't show - it could be a tad larger, though.
Hole in the panel
6-1/2" wide x 2-1/16" high
Flange or outside dimensions from the front:
6-5/8" x 2-1/4" high
Since I have the panel out I would be happy to test your prototype and post photos. Just let me know.
Jeff
Old Jul 2, 2019 | 06:10 PM
neinz's Avatar
Hole in the panel
Jeff
Thanks Jeff! I’ll try these dimensions out when I get home tonight. Would you happen to have pictures of the trip computer itself?
Old Jul 2, 2019 | 07:19 PM
Are these what you need?
Old Jul 2, 2019 | 07:45 PM
neinz's Avatar
Yes, those are great. Thanks. How thick is the wood panel? I'm just trying to figure out a way for the filler plate to mount to the panel.
Old Jul 2, 2019 | 08:00 PM
muttony's Avatar
Perpendicular tabs that are somewhat triangular so they can cause a snap in effect but can be easily pulled out. Probably 1 1/2 " long.
Old Jul 2, 2019 | 08:31 PM
It is not really a wood panel. It is sheet metal (I'd guess 18 or 16 guage) with a very thin layer of wood veneer. I measured it at about .07"
Old Jul 2, 2019 | 08:51 PM
neinz's Avatar
Great info guys.
Below are screencaps of what I designed so far. Being that a filler plate would occupy that space instead of the trip computer, having that long tab would not be ideal. So I made little tabs instead. Please let me know what should be changed.
Old Jul 2, 2019 | 08:56 PM
Looks great to me. If it's easy to print one let's see how it fits. If you would like me to do that, PM me and I'll give you my address.
Jeff
Old Jul 2, 2019 | 09:21 PM
neinz's Avatar
PM sent.
Old Jul 2, 2019 | 09:53 PM
muttony's Avatar
Can you put a rim around the edge? I was thinking one could inlay something in the depression and jazz it up. If there was a raised socket for the clock with a hole you could take advantage of the print texture and maybe paint the depression silver or something and then sand the rim down to 2000 grit and get a very smooth finish.
Old Jul 2, 2019 | 10:52 PM
neinz's Avatar
Jeff
Like this?
