84 XJ6 A/C system O-Rings
Old Aug 7, 2025 | 05:54 PM
David84XJ6's Avatar
Default 84 XJ6 A/C system O-Rings
I am replacing my A/C compressor and Receiver/Dryer after failed clutch.
Can't confirm overhauled unit from Rock Auto and new dryer have seals needed. lots of general instructions: if metric use these bolts and nuts. Put in the correct type, viscosity and amount of oil. Can't find any source for correct o-ring part numbers or the sizes SAE or Metric. I don't want to start removals until I have correct O-Rings.
Any recent experience in this area would be helpful.
Rgds
David
Old Aug 7, 2025 | 07:00 PM
Jagboi64's Avatar
They are O rings for the GM A6 compressor. They are thicker than usual O rings.
I believe this is the ones: https://www.rockauto.com/en/moreinfo...choice=0-0-1-1
They usually come in a domestic assortment of AC seals.
Old Aug 8, 2025 | 08:51 AM
yachtmanbuttson's Avatar
I have used NYLOG BLUE on ALL my Nitrile O-Rings on my A/C for years. It's a clear gooey, sticky, very viscous liquid that seals really well. And it doesn't harden. Pic attached.
Old Aug 8, 2025 | 03:16 PM
David84XJ6's Avatar
Thank you gents,
Assortment of green O-Rings, and NYLOG BLUE ordered.
Will summarize when I get all sorted
Rgds
David
Old Sep 6, 2025 | 07:49 PM
David84XJ6's Avatar
Reporting in: new A/C compressor in, with refrigerant pre-charge complete. My helper was engine lift, as body can't deal with all Jaguar small work spaces and the need for at least three hands.
Five small work session with body recovery needed between sessions. Bonus, found problem with Cruise Control vacuum leak, which also improved warm idle when sealed.
Thanks to forum members, I was willing to dive in, as recent experience is better than my memory of previous A/C projects.
Felt good to have nice test drive up the California coastline, with a car 1/2 my age.
Thanks Again
Rgds
David
NTL1991
XJ40 ( XJ81 )
Jun 10, 2018 08:40 PM
hershey
Aug 12, 2014 07:53 AM
Wascator
Aug 3, 2013 10:05 PM
skanoski
Jun 22, 2011 10:17 PM
bigdog
Aug 19, 2010 09:36 PM
