84 xj6 Suffering leaky windshields.
Old Apr 24, 2009 | 10:36 AM
Doug's Avatar
Never done it myself, so I'm no help there in terms of actual pointers. But the rubber around the windshield has nothing to do with the sealing against leaks....although it does a good job of sealing IN any water that gets in there :-)
If you have a leak the glass will probably have to come out for a re-seal although you might be able to just add some more sealant around the glass. A little hokey but it might do the trick.
I'd be worried that rust has already taken hold and the water is coming in thru the rust holes.
Good luck
Old Aug 28, 2009 | 05:06 AM
James L. Qeastar's Avatar
As for leaking windshields and and rear window seals. Dont screw around with adding goop around the thing. Order a FULL seal kit and drive down to your nearest windshield repair shop and have it placed in correctly. 99% of them can remove the chrome safley and put everything back together and keep it pretty. At the same time this will allow the car owner the chance to inspect the ENTIRE seal area for rust and get it fixed befor it becomes a Huge rust hole
ryan_border
Dec 23, 2015 04:27 PM
King Charles
Oct 16, 2015 01:25 AM
mat32essex
Oct 3, 2015 04:12 PM
dansxj6
Sep 28, 2015 08:02 AM
42Ajd
Sep 26, 2015 07:04 PM
