86 XJ6 trunk locked
Old Aug 19, 2022 | 03:08 PM
mikega's Avatar
Default 86 XJ6 trunk locked
Hello,
​​​​​​i have one 86 XJ6 which has the trunk locked, central lock could not open it.
Is there anyway to bypass to have the trunk opened?
Thanks for help in advance
Old Aug 19, 2022 | 03:24 PM
motorcarman's Avatar
Use the boot lid key?
Old Aug 19, 2022 | 03:35 PM
Darrenmb's Avatar
Veteran: Navy
Trunk isn’t on central unlocking, only locking! There is a modification that can make it both, but for now if you don’t have key, remove the license plate and you can manipulate the rod to unlock it, if you have another that you can open and look at the mechanism it will great improve your chance of opening it
Old Aug 19, 2022 | 03:54 PM
mikega's Avatar
sorry I forgot to mention, the key is not able to open it
Old Aug 19, 2022 | 06:50 PM
Jose's Avatar
in that case, you need to remove the license plate and try to grab the vertical Rod seen through one of the license plate screw holes with long thin needlenose pliers. This rod is attached to the latch and by pulling it UP the trunk lid can be opened.
the other solution is destructive: cut a hole between the license plate screw holes but nearer the two right hand holes, to be able to grab the rod and pull it. Then once opened, close the hole with a suitable plug.
yarpos's Avatar
this previous thread may help, it has some pics
https://www.jaguarforums.com/forum/x...t-lock-230316/
Old Aug 21, 2022 | 06:49 AM
mikega's Avatar
Thanks to all, I was able to unlock the trunk bit unfortunately I didn't make a video of that to share.
i applied the license plate holes method.
maxiedaniels
Sep 5, 2019 12:53 PM
95Leaper
Aug 30, 2016 05:35 PM
Nighteyez
Mar 19, 2014 12:06 PM
TopHatChef
Aug 9, 2008 08:13 PM
RickSku
Apr 23, 2008 09:56 AM
