Aging oil
Old Jun 27, 2008 | 07:25 PM
Markus's Avatar
Default Aging oil
I have a 1977 XJ6C, which sees less than 1500 miles use per year. It gets a 20-30 mile drive every month at least, to keep the gaskets intact (and for sheer enjoyment). I use Mobil One 5W30, which, needless to say, looks perfectly clean after a year and a half in the engine. Is there any need to change the oil based purely on the time it has been in the engine?
________
1999 XJR
Old Jun 28, 2008 | 05:38 AM
Default RE: Aging oil
IMHO you should change it at least once a year as oil can become acidic with use as and will contain condensation unburnt fuel etc.
Old Jun 28, 2008 | 11:38 AM
FactoryJaguarTech's Avatar
I agree, but being as **** as I am, I would say every six months. Just the short trips driving, startup etc....not great for the oil.
Old Jun 28, 2008 | 10:02 PM
Dennis's Avatar
ud
DITTO
Old Jun 29, 2008 | 06:05 PM
Markus's Avatar
Thanks for the replies, chaps. I will follow your advice.
________
1999 XJR
Old Jun 30, 2008 | 11:00 AM
ohsigmachi's Avatar
If you get it out every month and get it up to temp and run it for 30+ minutes at steady speeds, you will burn off the vast majority of condensation and fuel from start-up. As long as the carbs are in a good state of tune and not running pig rich I would have no issues with 2 years...I'm assuming the car is kept indoors in a climate controlled environment.
Old Jun 30, 2008 | 11:07 AM
Dennis's Avatar
ud
As cheap as oil is, (sorta speaking)why go the two years?..Every six months is a good measure..But if you burn the gas less..then add the correct amount of Stab-Bil to the gas to keep it fresh.
Rivguy
Dec 4, 2020 07:55 AM
Scarecrow
Mar 28, 2016 03:17 AM
hoodun
Oct 2, 2015 10:13 PM
Tim Goz
Sep 17, 2015 09:11 AM
