Air pump plug size
Old Feb 9, 2018 | 05:57 PM
sidescrollin's Avatar
Default Air pump plug size
So I purchased 1/8" BSP plugs for my air pump system but they just drop down into the hole the rail came off of. I bought this size according to a few threads I saw.
Are the pieces that the rail threads into simply adapters that thread into the head? Do I need to remove these and that is where the plugs go or am I just totally off on the size?
The rail looked to tighten down as a compression fitting so I'm guessing those are adapters that come out, but now the sun is down, so I can't check.
Thanks all.
EDIT: 1987 4.2 XJ6
Old Feb 9, 2018 | 06:15 PM
Jag-o-nomic's Avatar
Hi sidescrollin,
For Series 3 XJ6 six cylinder 1/8 BSP Tapered plugs should fit the bill.
I note your signature is 87 4.0 XJ6
Series 3 only came with 4.2 straight six or 5.3 V12
It could be that you have an XJ40 XJ6 in which case, above plugs may well not fit as the XJ40 was fitted with the AJ6 engine.
Good luck,
Nigel
Old Feb 9, 2018 | 06:30 PM
Sorry, I haven't had this car long and have had several 4.0 L cars so I keep thinking its a 4.0
My question is mostly about the adapter I guess. Does that short piece also need to be removed and the plugs go directly into the head?
Old Feb 9, 2018 | 06:31 PM
Doug's Avatar
Adapters, yes.
Remove them and then your plugs shoud go right into the cylinder head
Old Feb 9, 2018 | 07:07 PM
Thanks for confirming. Pulling the dead pump and rail cleans up the engine bay quite a bit.
Old Feb 9, 2018 | 07:46 PM
That area looks a lot neater and access to the spark plugs is much improved.
Old Feb 10, 2018 | 07:22 AM
Nanonevol's Avatar
I also bought some 1/8 to soon plug my '85 so I'd be interested to hear if these worked for the OP.
doug powell
Dec 5, 2011 09:30 PM
Craig Schmidt
Oct 26, 2011 05:54 PM
AntixSD
Apr 3, 2010 07:40 AM
1988xj6navy
XJ40 ( XJ81 )
Jun 20, 2009 09:02 PM
J.Bo
Feb 10, 2009 05:43 PM
