Another happy Pertronix customer
Old Jun 13, 2018 | 08:15 PM
Mkii250's Avatar
Default Another happy Pertronix customer
I can confirm that distributor D171618 Ignitor II with 45,000v coil 45011 works in an 86 Canadian spec XJ6, as I'm now running that configuration. It has smoothed the idle, which was quite lumpy. And throttle response seems crisper, especially at higher engine speeds. I haven't had it long enough to determine any change in fuel use yet.
Old Jun 14, 2018 | 06:55 AM
xjtony's Avatar
Yes i agree, I also fitted the pertronix distributor and coil too my Xj6. It definitely smoothed my idle also, its not perfect but a lot better. Also seems crisper and sharper throttle response when coming off the idle also..
Old Jun 16, 2018 | 12:22 AM
Bill Wiggins's Avatar
stupid question but will this setup work on a 75 xj6L series2?
Old Jun 16, 2018 | 08:03 AM
Mkii250's Avatar
Not a stupid question, yes it will work.
Old Jun 16, 2018 | 10:49 AM
Adrian L's Avatar
I just ordered a D177600 distributor for my '71 XJ6. Pertronix recommends the 40,000v 3 ohm flamethrower coil with this distributor, but I noticed other Jag owners recommending the 1.5 ohm coil. Does it make any difference?
Old Oct 24, 2018 | 10:02 AM
din888's Avatar
Good to know Petronix is making people smile
Can someone confirm we will not need the Ignition Amplifier should we go for Petronix? Thank you!
DIN
Old Oct 27, 2018 | 08:31 AM
Mkii250's Avatar
DIN
That's correct din888, the amplifier is no longer needed. However should you remove it, be aware that one of the bolt holes in the end of the intake manifold will cause an air leak if left open.
brianbill
May 17, 2015 04:10 PM
themajor7
Dec 16, 2014 10:42 AM
Elbartus
Sep 24, 2014 10:15 PM
Mkii250
Aug 14, 2014 04:34 PM
speedbuggy16v
XK120 XK140 XK150
Oct 24, 2013 09:24 AM
