Antenna damage.
Old Aug 26, 2023 | 01:36 PM
eggdoc41's Avatar
Default Antenna damage.
Hopefully I'm in correct forum (86 XJ6 s3). Tail light compartment exposed, antenna detached from cable to motor, motor in boot exposed . I think plastic cable with teeth is inside motor, making removal of motor necessary. So 2 questions at this point...
How to remove motor
How to pull old antenna from supporting tube
Thanks Big Cat for guidance
Old Aug 26, 2023 | 03:15 PM
Jose's Avatar
behind the bumper there is a hole and rubber grommet or rubber boot.
the antenna with cable is pulled out through that hole in reverse. The motor assembly bolts are removed so you can pull the entire motor and antenna from the trunk.
Old Aug 27, 2023 | 12:08 PM
eggdoc41's Avatar
It worked! I'll contact Retro Manufacturing re their unit. Thanks, thanks.
AustinBigSeven
Feb 12, 2022 07:11 PM
hafferf
Dec 6, 2014 09:14 PM
Sarc
May 21, 2013 02:52 PM
XKRNV
Feb 26, 2011 03:47 PM
1999_Jag_XK8
Apr 22, 2009 08:59 AM
