Any Ideas how fast an XJ6 will go
Received 6,317 Likes
Question: Is this car capable of 115-120 mph? That is what the speedo was swaying between at one point today. I have had around 100mph a number of times for short stretches of say 2-4 km of road, but today I found a long empty road(controlled environment and not a public road of course,just for any bureaucrats that may have snuck in with the humans).
The piece of tarmac was about 5-6 km long with no one in sight so I just floored the XJ6 for the full length, RPm was sitting around 4700-4800 and speed between 115-120mph.
Temp was normal the whole time ,even for a 37c day outside. Would you consider this a real speedo reading or not accurate?
I did not have a GPS with me to verify the speed, but it certainly felt like 200 kph.
o1xjr (11-25-2014)
Drove around 380km(256 miles on my speedo) round trip today to have a cold beer and steak sandwich with a mate during his lunch break in Kyogle.
Took the freeway there and the back roads home, handled great on the back roads between 40 and 80mph.
Attachment 101409
Attachment 101409
Soon carved my way to the front and made up the lost time(yep late for lunch). Oil pressure was at about 15 psi, but the mechanical gauge I had on it a couple of weeks back said I have 50 psi at 3500 rpm, so just kept that peddle to the metal (or carpet)as they say.
Received 9,008 Likes
Actually, Clarke, there is a metal stud to limit accelerator travel and keep one from literally sticking one's foot through the firewall. So you did indeed have the pedal to the metal.
My car is admittedly a bit different, but you do ask how fast an Xj6 will go not how fast an XK engine will go. I've had Nix at 135mph a time or two in search of top end (which I have yet to find as I ran out of road) with those new tires, and everything was smooth as silk.
It was exhilarating!
I do like to drive fast. I've even had Wart to 100mph when I'm in a big hurry but it isn't smooth.
LnrB (11-25-2014)
The speedo on both my 80s cars are accurate , what they read agrees with a GPS speed and agrees with a couple of roadside speed check displays we have in VIC. My wifes Subie gets increasingly optimistic with speed so to do 110kph you need to see 120 on the speedo.
If you know that you were doing 4700 RPM it should be possible to calculate road speed using that mathematical stuff if you can find enough beer and enough calculators.
MikeyB10 (01-24-2015)
Received 2,399 Likes
Steve:
Yeah, I composed a detailed posting on maths and more. IE11 ate it before posting.
LnrB:
The metal stud is there to prevent an over center. Not good, stuck "wide open". Been there, but with much less HP, so not as critical!!
Daughter comes later with thanksgiving lunch/dinner.
Happy thanksgiving from Coco and I.
He has had his breakfast and outing and I am sipping my AM coffee.
Jaguar 3/4 fixed. Football tonite. All is well in the Hutchins homestead.
Carl
LnrB:
Carl
I owned both Series I and II when they were current models and have a history of dropped valves, cooked pistons and failed big ends on a number of XK straight six 4.2 litre engines.
I once met an older Lady from South Dakota. She had once owned a Series I XJ12. She no longer owned it as she received a speeding ticket of over 120mph in the Jag. Her husband sold it because of the ticket, as she would not slow down. This meeting was in the middle 90s and the Lady was in her 80s. Yes a Series 1,2, or 3 can sustain speeds over 100 mph for long periods if properly tuned and maintained. Why else would the XK120 with the XK engine have set 5 world endurance records? I ran my Series 1 and 2 XJ6s hard to work as daily drivers for more than 10 years. Hard to maintain these speeds today with the congestion and the US drivers that cannot fathom driving without distractions.
If you've ever been to South Dakota you know there's basically NOTHING for mile after mile after mile; not unlike Montana. If you want to get anywhere, you have to drive to Get There.
[...] Hard to maintain these speeds today with the congestion and the US drivers that cannot fathom driving without distractions.
I actually called in and reported one of them once, who was crossing a double line on a blind curve, forcing oncoming traffic to take evasive action, scaring the **** out of everyone on the road. CHP rounded him up and threw the book at him as he was known to them for other infractions.
That felt Good!
The Datsun above, before the triple-s intake, used to be held at 5K rpm in fourth gear
for hours. The trick was to feather out the manual choke a touch to run it richer,
and run the tires on the white lines to avoid the hot asphalt. Alternating from side to
side of course. Little 165x13 78 series belted snows run at 40psi in summer
LnrB (11-29-2014)
