audio / nav upgrade
Old Feb 17, 2018 | 08:24 PM
andys-GR's Avatar
Default audio / nav upgrade
Starting to dry fit the new nav and audio unit. Android based Chinese e-bay special (I've fitted similar, double din units to two previous Porches and been very happy)
I need to make a custom bezel to replace the upper veneered part of the center console. I can't decide if I want to try and match the existing veneer, black plastic or brushed Aluminium.
The switch gear will be replaced by toggle switches in front of the radio head unit.
Attached Thumbnails audio / nav upgrade-20180217_185047.jpg   audio / nav upgrade-20180217_185003.jpg
Old Feb 18, 2018 | 08:22 PM
pjprofili's Avatar
Excellent idea! Which unit is that?
Old Feb 18, 2018 | 08:53 PM
andys-GR's Avatar
Its a hizpo 10.1" display single DIN. I won't fit as shipped but disassembling gives a separate single DIN body with long enough leads to route up to the display.
Mounts for the screen will have to be custom but should be straight forward.
H20boy
42
May 21, 2022 02:22 PM
jjsaustin
Dec 13, 2019 08:50 PM
Teck4Jag
Feb 11, 2017 01:55 PM
daboss085
Jul 11, 2012 05:46 PM
BuckMR2
Apr 2, 2010 02:45 PM
