beat a trans am
Old Mar 18, 2005 | 05:02 PM
Patrick's Avatar
Administrator
Default RE: beat a trans am
did you go with him??
Old Mar 23, 2005 | 02:11 PM
Patrick's Avatar
Administrator
what is your dads car?
Old Mar 24, 2005 | 04:04 PM
Patrick's Avatar
Administrator
hmmm...would be a close run, i think...you should try to get your moms car to the dragstrip sometime..
Old Mar 25, 2005 | 03:43 PM
Patrick's Avatar
Administrator
is your GT an auto or 5 speed?
Old Apr 15, 2005 | 06:20 PM
Patrick's Avatar
Administrator
hmmm...if his mach is a 5 speed, he should smoke you..if his mach is an auto, you should have a good chance...the mach didnt add that much performance over the abse model from the same year, but from a 94, i think it is quite a bit higher hp
Old Apr 16, 2005 | 07:23 PM
Patrick's Avatar
Administrator
hmm..good point...you could get one of those fancy "blue fire extinguishers" in the trunk..that woudl even the score.
Old Sep 2, 2009 | 02:15 PM
StypeRowner's Avatar
Default Hooo Raaa !!!!!
I can smell the burning rubber now !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 2, 2009 | 08:55 PM
budsang1's Avatar
Wow...back from the dead!!
Old Nov 10, 2009 | 09:38 PM
redjag8841g's Avatar
WOW, thats great mileage for a SN-95. Sounds like its in great shape, keep it that way. As for your Dads and Moms car, I can attest that the Mach 1 will take the Jag. I have an 04 Mach 1 and an 88 XJS V12 and the Mach 1 will walk it no problem. Although you get a lot more head turns in the Jag.
Old Jan 17, 2010 | 11:18 AM
chazaroo's Avatar
Will do.
Old Jan 17, 2010 | 12:12 PM
Is this a Twilight Zone area of the forum?
n2audio
19
Jan 20, 2025 09:35 PM
tampamark
Oct 11, 2015 10:03 PM
Manjag
Oct 1, 2015 05:34 PM
mrplow58
Sep 30, 2015 08:56 AM
