Bleeding rear brakes
Old Feb 27, 2017 | 09:59 AM
Calvey's Avatar
Default Bleeding rear brakes
Right! Who is responsible for the placement of the bleed nipple on the rear brakes of my series 2??? I love the principle of the inboard system, but really!!!
my question is how are you meant to get a spanner on the nipple without having to remove the exhaust?
I'm going to have a crack at flushing the whole brake system on the weekend, my gut feeling is that the master cylinder is probably past is best, but I'll give it a go anyway.
Old Feb 27, 2017 | 10:02 AM
jimbov8's Avatar
I believe some people have fitted an extension piece so the bleed nipple is on the outside of the cage. Maybe worth thinking about for future maintenance.
Old Feb 27, 2017 | 11:20 AM
Doug's Avatar
There's enough room, just, unless the exhaust system has shifted due to worn hangers or whatever. You may have to force/push/pry the exhaust pipes over a bit.
Old Feb 27, 2017 | 11:27 AM
Calvey's Avatar
Thanks DD, I was just thinking about those adjustable ring spanners that I've seen at the toy shop,, I mean,, tool shop, I might grab an 11mm one and try that as well.
Old Feb 27, 2017 | 11:30 AM
JagCad's Avatar
I've a pair of sets. One in metric and one in SAE. OK for light duty, and very handy.
I reserve them for "special events".
Carl
Old Feb 28, 2017 | 07:42 AM
smith356's Avatar
Default bleeder nipples
I just ordered new F&R bleeder vales from Jegs. They have a ball valve which closes to prevent air from entering the system - attach your hose to valve, get in car and pump away.. one man operation and no need for vacuum pump.
Russel 3/8x24 front
Russell 10mmx1.0 rear
9.99 per pair
PS... hose needs to be submerged in cup with some brake fluid
Old Feb 28, 2017 | 10:30 AM
Calvey's Avatar
Thanks for the advice guys, Ive bought a vacuum pump today so I'll have a crack with that!
Old Mar 2, 2017 | 06:50 PM
ronbros's Avatar
just finished bleeding rears, some dirty brown stuff came out!
used a clear plastic hose and hand vacuum pump, must have had moisture in fluid!
brakes are great now, fronts were done about a month ago, that fluid was clear like new!
i never do maintenence often enough!
