Blower stucks...
Old Sep 24, 2019 | 01:52 PM
Rudy Mensink's Avatar
Default Blower stucks...
Hello Jag-friends;
I want to remove the right airblower, but is will not come off, it seems it is stuck by the air-inlet, how can I get it loose?
thanks in advance , regards, Rudy
Old Sep 24, 2019 | 04:04 PM
Jose's Avatar
what year XJ ?
during removal, you are supposed to maintain the lower floor flap fully open by inserting a wedge to keep it in the open position.
if the floor flap is not open, the entire blower case will not come out.
Old Sep 25, 2019 | 09:08 AM
In addition to Jose's advice, I will say you will wiggle and jiggle, pull and shove, perhaps utter a few choice words, and then without your knowing what you did or how, the blower will simply fall out in your hands. I have removed 4 of these.
However, you do NOT want to try forcing it with tools! Opening the lower flap closes the upper flap which extends into the fresh air intake just under the windshield beneath the grill, and allows the fan assembly to be removed through a precisely fitting hole.
By now the original nylon links between the two flaps are hard and brittle and if you break them THERE ARE NO REPLACEMENTS ON PLANET EARTH!
So, in the words of another member, one must use Gentle Violence to get the fan loose and into your hands without damage.
However, it Can be done!
Old Sep 25, 2019 | 09:25 AM
Jose's Avatar
Elinor, do you mean the nylon Pins? they are available.
the XJ uses them in many places.
one place is under the rear seat. There are plastic covers on each corner held by these pins.
another place where there are 4 nylon pins is at the front bumper black plastic finisher.
previous models like the S type and 420 of the 1960s also used the same pins.
I have a packet of them. got them from Jaguar Services in Illinois. Have replaced a few in both my blower case linkages.
Old Sep 25, 2019 | 09:54 PM
Well, I'll be Jiggered as my old Grandad would say!
Thank you, Jose, I obviously had No idea these were available.
I'll learn to ask you about all arcane bits of Jaguarania before I post their extinction.
Old Sep 26, 2019 | 05:18 AM
Jose's Avatar
yes but what I didn't tell you was the date I bought two of those pin packs. Must have been 20 years ago! So you might be correct about their being extinct.
Old Sep 26, 2019 | 08:33 AM
Dear Jiggerers; i hear what you say; i wil start wiggle and jiggle and hope for the best. Another problem is de heater core, totally rotten away. Perhaps that a heater core from a X300 will fit? I have bought one from Germany, it will arrive next week. Anyway, it's a lot of bring the ol' lady back to her grandeur. Thanks all!
Greetz, Rudy
Suede
May 19, 2020 08:30 PM
ShaneClara
Dec 8, 2014 05:42 AM
ShaneClara
Nov 30, 2014 07:17 PM
marke
May 11, 2013 11:19 AM
m0t0rm0uth
Nov 20, 2009 02:27 PM
