Bonnet problem XJ6
Old Jun 7, 2016 | 01:33 PM
philipa's Avatar
Default Bonnet problem XJ6
Hi .Unfortunately the bonnet cable has broken on my XJ6 and am unable to open it now .Anyone know how this can be done ?.Hopefully someone will help me !
Old Jun 7, 2016 | 01:56 PM
Darrenmb's Avatar
Veteran: Navy
There are holes in the wheel wells to access the latches, or so i am told.
Someone will be along shortly thats actually used them and will give you a more detailed description on where and what to do.
Old Jun 7, 2016 | 02:20 PM
philipa's Avatar
There doesnt seem to be any holes in my one ...they must have been welded up at some stage !.Think i am going to have to use a hole cutter and drill somewhere ,But where is the question ,as dont want to drill into anything under the hood !
Old Jun 7, 2016 | 02:59 PM
Default Energency Hood/Bonnet Release
In the upper wheel well on both sides is a plug (if it hasn't fallen out). It's easy to see because of the 2 nuts securing the latch to the fender wall.
Upon removing this plug (you might not want to lose it), insert a largish flat screwdriver pointing Forward.
You're looking for this:
The red arrow indicates the plug from above. The green arrow is the "lever" which you want to push BACK to release the latch. It's a simple slide mechanism.
You can see how you might need to poke around for a bit until you're sure you're on the correct object, but when you find it simply pry against the edge of the hole and the latch will release.
If you think it's a good idea, you might want to lube the latch components for easier operation.
The cable will last longer as it will pull easier if this is done once in a while.
Old Jun 7, 2016 | 05:08 PM
philipa's Avatar
Thanks for the info ....will get my mechanic to try this tomorrow and will let you know if successful .Thanks a lot ,appreciate the help .
Old Jun 8, 2016 | 07:41 AM
o1xjr's Avatar
Welcome to the forums Philipa.
Check out this old thread.
https://www.jaguarforums.com/forum/x...es-1-a-125609/
When you get a moment please post an intro thread in the new member area.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Craighead
Jun 14, 2016 06:46 PM
Teejay
Jun 11, 2016 06:34 PM
yyk
Jun 7, 2016 05:50 PM
impster
Jun 6, 2016 05:45 PM
Maraud
Jun 4, 2016 12:02 PM
