Brake issue....
Old May 22, 2009 | 10:45 AM
Kamak86's Avatar
Default Brake issue....
Brakes work great until yesterday, It is really hot and muggy out while driving. I notice my brake petal needs to be pressed a little more then usual. about 30 mins later the petal sinks even more. about an hour after that i have slim to none brake pressure, and it no longer stops the car it just slows it down. THINKING i checked the fluid, its full. I checked and pumped the brake while in the driveway, nothing no pressure. I check the ground and the hoses, no leaks. I leave it set for about 2hrs come back out to really start invesgiating the problem, and to my surpise i have full brake pressure. When i turn the car on and press the brake pedal i can feel it start to relive the pressure. Someone told me it could be master cyclinder or he told me some sort of vacumm failure. I thought it might be a valve that is going bad letting fluid back in somewhere.
Old May 22, 2009 | 11:41 AM
moronthethrottle's Avatar
Are you using DOT 4 brake fluid? It sounds like the fluid is getting hot, or even boiling while running. Castrol GT-LMA has a high boiling point, but the Jaguar Super DOT 4 from your Jag dealer is the best-500 degree boiling point.
Others may have better ideas on seals, cylinders, etc as you mentioned that may help you out.
Old May 22, 2009 | 11:50 AM
ken@britishparts.com's Avatar
If the pedal sinks, it's got to be master cylinder.
Old May 22, 2009 | 12:16 PM
Kamak86's Avatar
hmm would the master cylinder go in and out? i would assume if it was bad it wouldnt build pressure back up after sitting, is there a wayy to check the master cylinder?
Old May 22, 2009 | 12:37 PM
It's not common, but can happen. It's probably some sort of internal bypass around the seals. Temp may effect it.
Old May 22, 2009 | 12:41 PM
Kamak86's Avatar
lets say the MC is bad, how do i go about replacing it?
jdzubas
Oct 4, 2015 09:14 AM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
