Braking response problem.
Old May 9, 2026 | 11:10 AM
Billbuck's Avatar
Default Braking response problem.
So my 1977 V12 XJC has what appears to be a brake assistance problem. Once in a while, especially at the start of a trip, the brakes don't appear to react well, and a second 'shove' of the pedal is needed. After that it's fine for a while but may recur. I've checked all the rubber hoses to the servo and the vacuum reservoir are in good shape and replaced any that looked in the least bit tired. I have vacuum pump with guage if anyone knows what else I should be checking or what other factor might be causing the poor response.
Old May 9, 2026 | 11:24 AM
Greg in France's Avatar
Master cylinder needs replacing?
Brake calipers starting to stick?
Old May 9, 2026 | 12:46 PM
Doug's Avatar
+1 on the master cylinder failing as a strong possibility
And/or air in the system
Old May 10, 2026 | 03:42 PM
slofut's Avatar
Agreed and check the one way valve in the vacuum line to the booster. I've had good luck with the "replacement" masters on amazon, and terrible luck refurbing the proportioning valve. Have removed said valve and am eliminating it as per ser 3 cars as we speak ...after I finish repairing the paint damage on the inner fender and frame rail (a real bicth).
Old May 11, 2026 | 12:06 PM
Billbuck's Avatar
I'm not sure my car has a one-way valve in the line to the booster. The vacuum feed tube comes from the engine cross brace directly into the booster. There is a valve is in the face of the booster which I have tested and works. Also the remote vacuum tank under the wing holds vacuum.
michaelgilbert
Nov 9, 2023 11:08 PM
Raptorcize
Sep 16, 2023 05:05 PM
J_C_R
Aug 21, 2022 10:41 AM
Mac Allan
Nov 12, 2016 01:22 PM
DpezXK8
Jul 8, 2011 06:16 PM
