Car stalls as soon as I take off
Old May 24, 2022 | 07:30 AM
series3man's Avatar
Default Car stalls as soon as I take off
Series 3 1983 4.2 van der plas. it starts and idles OK when go to take of it has no power, has new fuel regulator, new brake booster diafragm, checked the fuel pressure, had injectors cleaned, new fuel pump and coil, checked everything for air leaks, AFM been checked, new plugs, all sparking ok, a diode replaced i the middle electric block on the firewall, fuel tanks been cleaned out. Any ideas?
Old May 24, 2022 | 08:54 AM
Jose's Avatar
check the transmission fluid when engine is cold.
Old May 24, 2022 | 09:18 AM
Doug's Avatar
Originally Posted by series3man
Series 3 1983 4.2 van der plas. it starts and idles OK when go to take of it has no power?
The thread title says “stalls”…. which I would interpret as the engine stops running.
“No power” implies the engine stays running.
Please clarify exactly what’s happening.
If the engine stays running but the car won’t move then Jose’s advice to check the transmission fluid is your best next step.
Old May 24, 2022 | 01:23 PM
Brewtech's Avatar
You should take a good look at the little plaque on the car. Im sure it reads, Vanden Plas. You should know this as the owner of such car. Other than that, intake leak, or fuel supply is having trouble with the demand.
Old May 24, 2022 | 07:59 PM
Bill Mac's Avatar
One possible cause is a partly blocked fuel filter.
It allows sufficient fuel through to support the idle but not enough to get real power.
Fuel pressure would seem OK but no real fuel flow when the system demands it.
Old May 25, 2022 | 01:19 AM
sov211's Avatar
Finally, the coolant temperature sensor may be faulty - if so, the engine will not be receiving the “enrichment” needed during the warm-up period, and this results in stalling. “Been there and done that “. The sensor is not expensive and is very easily replaced - and it is easily accessible on the engine.
Old May 25, 2022 | 06:42 AM
Darrenmb's Avatar
Veteran: Navy
I second the fuel filter! I had similar issues ( but inhave smaller inline filters before the change over valve, and car would bog down and sometimes backfire through the intake ( and then blow bellows off of throttle body) but only using right tank! My suggestion it to replace fuel filter and add two smaller inline ones before the valve! Fixed all my problems
Old May 26, 2022 | 08:28 AM
series3man's Avatar
Default stalls
yes it stops running, have replaced coolant sensor as well and the fuel filter, trans fluid is OK as well, mechanic changed to another AFM 500 kms ago and was OK tho could have gone wrong since, could the idle mixture screw cause this?
Old May 26, 2022 | 08:40 AM
Jose's Avatar
engine shuts off when you put it in gear, right?
Old May 26, 2022 | 10:39 PM
Brewtech's Avatar
Intake leak, check everything. Including brake system, smoke test it.
Old May 27, 2022 | 12:29 AM
series3man's Avatar
Wots the easiest way to make smoke?
Old May 27, 2022 | 12:52 AM
Doug's Avatar
With particular attention to the duct from the AFM to the throttle body
Old May 28, 2022 | 12:21 AM
series3man's Avatar
can u buy a can of spray smoke?
Old May 28, 2022 | 08:12 AM
Darrenmb's Avatar
Veteran: Navy
Some people use a cigar, I have used the dog machine. That I have for Halloween
Old May 28, 2022 | 08:36 AM
Jose's Avatar
Tiparillos won't make you cough when you inhale. 7-11 has them.
Old May 28, 2022 | 05:47 PM
Brewtech's Avatar
Amazon Amazon
I plan on getting this soon. I have to test my intake asap
Charliebravo
Jun 6, 2016 05:17 PM
rcarpenter
XJ40 ( XJ81 )
58
Oct 2, 2011 01:22 PM
rinaldi63
Aug 9, 2010 02:41 AM
joeyfroy3
XJ40 ( XJ81 )
Dec 31, 2008 06:39 PM
