Car Won't Crank When Hot
Old Dec 16, 2018 | 12:05 PM
mikega's Avatar
Default Car Won't Crank When Hot
Hello,
We have recently detected another issue with the XJ6 - S3
The problem with the car is when the engine gets hot and the ignition is turned off, the car never starts unless the engine cools down.
What might be the possible issue now and how do i get it fixed?
Mike
Old Dec 17, 2018 | 12:31 PM
JagCad's Avatar
Two suggestions:
1. Poor connections. Battery cables and the under the car ground.
2. The starter is failing. Replace or refresh.
Carl
Old Dec 18, 2018 | 06:08 AM
Jag-o-nomic's Avatar
Hi Mikega,
Please clarify 'won't crank'
The engine literally won't crank over, or
engine cranks over but won't ignite (start).
As JagCad say's, if it won't crank then there is most definitely an electrical issue.
If it cranks over, but doesn't start when hot, then other factors come into play, like
weeping fuel injectors
Faulty coil / amplifier
Bung Temp Sensor
A longer shot - wiring harness flaky
More specific info, more specific diagnosis.
Cheers,
Nigel
Old Dec 18, 2018 | 08:11 AM
Doug's Avatar
Originally Posted by Jag-o-nomic
Hi Mikega,
Mike has two postings on the same issue. He has a true 'no crank' problem. That is, the starter does not operate
The (what should be) common terminology to differentiate is "No crank, no start" and "Cranks but won't start"
Engine Will Not Crank Checklist
Old Dec 18, 2018 | 06:25 PM
Well that's more confusing than a wiring diagram :-)
Old Feb 28, 2025 | 10:24 AM
yellowbandit's Avatar
DELETE
Michael1991
XJ40 ( XJ81 )
Nov 17, 2024 07:53 PM
Terrific
Aug 3, 2018 03:34 PM
Hernan Quinonez
Nov 17, 2016 06:48 AM
jagdayn
May 14, 2012 10:46 PM
the barder
Jun 29, 2011 07:06 PM
