The Carburettored V12 backfifing, and running poorly solution
Old Jul 17, 2022 | 11:19 PM
Eggleton's Avatar
Default The Carburettored V12 backfifing, and running poorly solution
Good afternoon Team Jaguar/Daimler, and an especial warm welcome to the V12 owners.
I have a Series 1 Daimler VDP Double Six (ostensibly the same engine as the Series 3 E-Type engine). The car had been running poorly for some time, lacking power, not starting reliably: hot or cold, backfiring under acceleration, and most embarassingly stalling at idle, or stopping intermittently when coasting at low speed.
Fault Isolation:
a. took the carburettors apart, and rebuilt them with SU/Stromberg kit. Several problems identified:
i. temperature and vaccum bypass valves full of soot, rebuilt these and reset to the factory tolerances;
ii. needle settings in various states of adjustment, but varying significantly;
iii. float valves dirty, float bowl had a sand like substance in them;
iv. Fuel inlet gauze filter blocked with what looked like silt.
b. Despite rectifying all these problems the car improved, more power, started better, but still exhibited the same symptoms.
c. Vaccum advance wasn't working, bought a new one;
i. Problem still evident but much improved power.
d. Stripped down distributor, looking for damage of siezed mecanical advance etc. Removed all spark plugs, and examined colour/condition.
i. Spark plugs were significantly different in colour, however found that they conformed to a diametrically opposed pattern i.e. the sooty ones were opposite to each other on the distrbutor sequence, whilst the sandy good burn ones were also opposite each other on the distributor sequence;
ii. After closer examination it appears that the bushes in the distributor were worn, and the rotor arm was taking a slightly eliptical path inside the distributor cap, making good contact with some parts of the dsitributor and hardly any/intermittently with others;
iii. I had a spare unit from a Series 2 V12 I am restoring, and replaced the faulty unit;
iv. Replaced the plugs with NGK (do not use any other plugs in your V12, they are not equivalents);
iv. Retimed the car
Problem has dissapeared.
Regards,
Chris
Old Jul 18, 2022 | 08:16 PM
Brewtech's Avatar
Dizzy’s are always overlooked. Great work!
Old Jul 27, 2022 | 04:18 AM
bullittandy's Avatar
I just completed the same process with my carb'ed V-12. This post will be helpful to future searches so thanks for sharing.
Rescue119
Jul 21, 2022 08:07 AM
Alan E L
Sep 22, 2019 04:41 PM
prettydaim
Sep 10, 2015 04:27 AM
Dave2254
Jan 27, 2015 01:14 PM
ragtop00
E type ( XK-E )
Dec 13, 2012 09:01 PM
