Check valve part number
Old May 30, 2015 | 06:59 AM
amaezing's Avatar
Default Check valve part number
Does anyone know the part number for the fuel check valve?
None of the parts houses know it and I know I read it here somewhere, but I'm not having very good luck finding it right now.
Thanks in advance.
Old May 30, 2015 | 07:10 AM
JgaXkr's Avatar
Are you referring to the check valve that is mounted in the trunk in the r/f corner? If so that we used to go to a Volvo dealer & get them. You need to reference one of the old cars with the D system EFI.
Old May 30, 2015 | 07:39 AM
amaezing's Avatar
That is the one. I will give that a try. Getting a bit annoying every time I start it, to have to crank and crank. It's the last piece I need to replace on the fuel system. Thank you.
Old May 30, 2015 | 07:56 AM
JgaXkr's Avatar
I think on the Volvo it screws into the pump.
Old May 30, 2015 | 07:59 AM
Doug's Avatar
CAC2027
Item #5 in this illustration:
Fuel Feed Pipes and Hoses-Trunk - Parts For Series III Saloon | Jaguar Heritage Parts UK
When cranking the fuel pump will pressurize the fuel rail very quickly....like within a couple seconds. If you are having to crank-crank-crank for 5-6-7 seconds then you might have a different problem
Have you tried priming the fuel system before cranking? Any difference in starting?
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
