Cooling System (I know its probably been done to death)
Old Dec 1, 2012 | 05:03 AM
Stevecosta's Avatar
Default Cooling System (I know its probably been done to death)
Hey guys,
I have been looking at upgrading the cooling system in my 1988 Sovereign V12 (XJ12).
I have been looking at a fan set-up like this one v12s - Official Website (may have to open up the fan system tab.
Now if I were to opt for the twin fan setup with the intergrated oil cooler. Would I be able to get a custom radiator made up that incorporates the original oil cooler as part of the new radiator? or do you think it would be a waste of effort? (just thinking the higher capacity would increase the longjevity of the system)
Anyways keen for any input on the matter all I know is that if i dont do something I dont think I'll be taking the old girl out over the summer
Thanks in advance
Steve
Old Dec 1, 2012 | 06:37 AM
Steve,
ALL my V12's, HE and PreHE had the Ford Falcon (EF/EL from memory) twin thermo fans fitted. The RH fan was thermo controlled, and the LH was A/C only.
I switched the thermo unit with the 85c switch already in the lower hose inlet. The A/C unit was simply relay fired via the compressor supply wire.
OF COURSE the radiators were first removed and recored, or tanks off cleaned, and ALL new hoses. The thermostats were replaced with correct length units (some of the Jag ones are toooo short) of 82c setting.
The ignition timing was also set to the correct spec, and all those silly things that go bugga up were also sorted, such as mechanical advance mechanism, vac advance capsule, wiring etc.
My V12's NEVER, EVER ran hot.
The last outing in the XJ-S was to Mildura and it was 44c, and nothing got any hotter than it should. Even in Adelaide's summer peak hour traffic crawl, with the A/C on, the thermo fan (RH) rarely activated.
I also DO NOT run the trans exchanger in the radiator, in fact they were physically removed when the radiators were serviced, and I have a simple after market "large" cooler out the front.
At the time all 3 of the V12's were daily drivers, in the TRUE sense of that phrase.
Old Dec 1, 2012 | 02:25 PM
Stevecosta's Avatar
Hi Grant,
Thanks, what sort of mods if any are required to fit the el/ef fans? (If you can recall)
Where did you purchase the aftermarket cooler?
Do you have any pictures of the setup I can see?
Thanks very much
Old Dec 1, 2012 | 09:31 PM
Jose's Avatar
there are several custom-radiator manufacturers, all very expensive. One is Mr. Jaguar in Dallas, www,mrjaguar.com
Old Dec 1, 2012 | 11:13 PM
Stevecosta's Avatar
Do xjs radiators fit in xj12s?
Old Dec 1, 2012 | 11:31 PM
Doug's Avatar
I've often wondered if the fan assembly from an X300 would fit?
95 96 97 Jaguar XJ6 Radiator Fan Motor Fan Assm | eBay
Old Dec 1, 2012 | 11:34 PM
Doug's Avatar
Can't positively swear to it but I think so, yes.
I feel better narrowing it down to pre-facelift XJS V12 HE radiators are the same as similar vintage Ser III V12 radiators.
Old Dec 2, 2012 | 04:29 AM
Steve,
Got heaps on that fit-up, and the files are largsih, so send me a PM with your email, and I will send for you.
The XJ12 and XJ-S V12 radiators are the same for the same years.
Like Doug said, PreHE same in both cars, and HE same in both cars. Up to about '91 from memory.
trosty
26
Dec 18, 2022 06:40 PM
willtoliv
Oct 2, 2015 12:18 PM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
1100me
Sep 7, 2015 06:26 AM
