Correct tires for my 1987 XJ6
Old Nov 9, 2014 | 05:44 PM
wnlewis's Avatar
Default Correct tires for my 1987 XJ6
Where can I get correct tires for my 1987 XJ6? It takes P5 215/70 VR 15 tires.
I don't intend to go as fast as an R rated tire will go, but the sidewall strength is important for tire longevity and safe driving.
Thanks for the help.
Neal Lewis
Old Nov 9, 2014 | 05:50 PM
Doug's Avatar
I believe you meant to say "...as fast as a V rated tire will go.....".
I don't know of any tire manufacturer that publishes sidewall specs but we assume...probably correctly...that tire with a higher speed rating and/or higher load rating will have stronger sidewalls.
Since V-rated (o even H-rated) 215/70x15 tire are almost extinct we're left with looking at highest possible load ratings. If you can find that size with a 98-99-100 load rating you'll probably be getting the stronger sidewall you're looking for.
Tire Rack is one good place to start the search
Old Nov 9, 2014 | 09:08 PM
wnlewis's Avatar
Doug,
Thanks! That was exactly the sort of information I needed.
Yes the rating is V not R.
I will look at the load ratings and see what I can find in the 98 to 100 range.
Thanks again.
Neal Lewis
smith356
Oct 7, 2015 06:41 PM
Gatsby
Sep 6, 2015 11:52 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
