Cranks with Remote Switch but Won't Crank With Key
Old Mar 12, 2023 | 07:18 PM
'85Jagbait's Avatar
Default Cranks with Remote Switch but Won't Crank With Key
my 1985 xj6 won't crank with the key, will crank with remote switch
Old Mar 13, 2023 | 09:59 AM
Don B's Avatar
Hi '85Jagbait,
Welcome to the Jaguar Forums! It's great to have you with us!
I have moved your first post from an unrelated thread in the X300 forum to start your own thread here in the XJ6 & XJ12 Series I, II & III forum. This is the proper forum in which to post questions about your Series III XJ6.
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old Mar 13, 2023 | 11:55 AM
Chris Scott's Avatar
Well, I'm no expert, but as I understand it the remote switch is meant to bypass the key switch, so I reckon I'd be looking at the key switch - loose/disconnected terminals?
It's a later car than what I'm used to, so there could be some kind of relay or card somewhere in the circuit, but still - it couldn't hurt to take a look under there and confirm all is clean and tight in ignition switch land.
Old Mar 13, 2023 | 01:05 PM
sov211's Avatar
Yes, it is very likely wear in the ignition switch itself. You might try jiggling the key while trying to crank (perhaps easier to say than to do). A replacement switch is probably called for.
i had exactly this issue with my MGB after 28 years of daily use.
Old Mar 13, 2023 | 02:45 PM
Darrenmb's Avatar
Veteran: Navy
Where are you connecting the remote switch? I had a similar issue and it was the relay that was bad! It can all be traced with a test light! I was getting 12 volts to relay when in start position , but nothing coming out!!
CartF1
May 5, 2018 08:15 PM
bigbadbill
Jun 12, 2017 08:19 AM
rossstein
Jan 22, 2014 07:20 PM
atalaya
General Tech Help
Aug 2, 2013 06:14 PM
