Crankshaft position sensor
No crankshaft ?? I'm pretty sure it does, but No CPS for sure.
Correct. No need for a cam position sensor, as it has a distributor. The EFI is fairly crude by today's standards, it receives a trigger pulse from the ignition module for engine speed and batch fires the injectors. No attempt is made to synchronize the injector firing with crank position.
Millarjs
Oct 10, 2023 12:10 PM
relaxed00
Mar 10, 2012 04:53 PM
