Crankshaft position sensor
Old Apr 6, 2026 | 06:16 PM
Saemetric's Avatar
Default Crankshaft position sensor
Settle an argument with a friend I said the S3
4.2 engine does not have a crankshaft or camshaft position sensor. Am I correct.
Old Apr 6, 2026 | 06:42 PM
Jose's Avatar
Originally Posted by Saemetric
Settle an argument with a friend I said the S3 4.2 engine does not have a crankshaft or camshaft position sensor. Am I correct.
No crankshaft ?? I'm pretty sure it does, but No CPS for sure.
Old Apr 6, 2026 | 06:54 PM
Saemetric's Avatar
Should have said crankshaft position sensor or camshaft position sensor.👌
Old Apr 6, 2026 | 07:47 PM
Jagboi64's Avatar
Correct. No need for a cam position sensor, as it has a distributor. The EFI is fairly crude by today's standards, it receives a trigger pulse from the ignition module for engine speed and batch fires the injectors. No attempt is made to synchronize the injector firing with crank position.
Millarjs
Oct 10, 2023 12:10 PM
dcjag22
Oct 4, 2022 06:47 AM
3kgtjunkie
Aug 4, 2020 10:06 PM
relaxed00
Mar 10, 2012 04:53 PM
Idrivejags
Dec 1, 2008 07:26 PM
