Dangerous driving while switching petrol (or gas if you like) tanks
Hi all,
please advice and help me to stay safe
The thing is : When switching petrol tanks on my '72 XJ6, the engine is taking a lot of time (like 5 seconds) before it is sucking a decent amount of petrol out of the fuel pipes. annoying but still manageble.
It gets even worse when i completely empty let's say one tank 1, then switch over to tank 2, then stop at the station and refill tank 1, and then, while driving again on tank 2, switch back to tank 1. It takes like ages. Even when driving 80 km/h it takes so long the car just almost gets to a halt >> hazards lights on, annoying everyone , and putting my jag and myself in danger.
I assume because i completely emptied tank 1 before, when i later switch back to (a refilled) tank 1, all fuel hoses are empty and it needs tiem to fill up. Or is it air that is obstructing the flow. Or something else that is causing such a long time before things settle again ??
Thank you so much for your generous thoughts on this.
Every decent reply is rewarded with a picture of my belovered Jag :-D
Jan
Jan
In conclusion I would not recommend running the tank dry if you can avoid it. Yes the tanks have a mesh strainer inside, but debris will still get through to the fuel fliter and you will end up changing this more often.
I try to keep all the changeover bits exercised. Every time I start the car I switch fuel tanks. This keeps the level in the tanks about equal so no matter which fuel guage is reading you know about how much you have in total. Before I started this routine I saw the guage showing low and switched over and I thought I had another 11 gallons but I had forgotten that tank was empty too. Jan, if you do this your changeover will be while you are safely sitting still. Let's see those photos.
Jeff
Jeff
regardless of what Series the XJ-6 is, you should change tanks every 10 miles (or km equivalent) and not empty either tank before switching tanks. Like they do in airplanes? to keep the weight balanced and the switching valves exercised. My two cents.
I agree with idea...but every 10 miles ? Wow!
I flip the tanks at 1/4 tank intervals
Sorry Frazer, but the OP appears to have a series 1 which do not have a changeover valve. My series 1 with new SU pumps takes about 2 seconds to recover if I run the tank dry. I don't do this often but have done so to check fuel consumption. I would suggest that Jan checks out the performance of each fuel pump by running fuel into a container and having an assistant operate the switch. The scenario where the empty fuel tank is filled and then switched on is quite normal - it will take the pump about three or four seconds to push that fuel to the carbs and fill the bowls.
There is a 1969 4.2 XJ6 at a junkyard near me and I was looking at it last weekend. Definitely a single SU pump and changeover valves, so your changeover valve is probably sticking. On a Series III you should be able to switch while driving without any hesitation, and on my earlier Daimler with twin tanks and twin SU pumps again I can switch while driving and it's unnoticeable. Something is clearly wrong.
I run one tank empty, then switch to the other and then refuel. Then I know my other tank is always full, I don't run low, go to switch tanks and find it's empty. Only changing when empty also reduces wear on the changeover valves.
Are there/should there be check valves in the system, I wonder?
For me, it was drive til one tank was at 1/4. switch tanks. Drive til that one is at 1/4.
go to gas station and fill or clse to fill. i prepay and jsut estimate. At the timre., My 60 bucks did the fill. Now, not even close.
That is when i drove. have not done much of that for a spell.
Carl
Carl
My old 1969 Series 1 had two external SU fuel pumps and shared the plumbing, I would keep tanks even. Unfortunately I did have one fail and had to replace that pump, but never run the tanks dry, bad things happen.
I would second on how Jan's fuel system is actually set up help make a diagnosis. If the system is stock I would suspect the changeover switch on the dash first. My old XJ6-C would sometimes stumble when changing tanks and rapid cycling of the switch several times would restore order.
Double-check the integrity of the pumps - I've had an S.U. pump suck air without betraying a leak...
Hello all,
Just wanted to get back to you on the issues i had.
I took your advice and do not empty tanks completely anymore. Cleaned out and replaced the fuel filter once more. Drove another 1000km and since then no more trouble and the tank switches go without any hesitation from the engine.
Jan
Jan
CalebJAG
Nov 14, 2021 06:25 PM
kalexander
Jun 16, 2016 11:16 AM
