Dash board delete
Old Feb 6, 2022 | 02:03 PM
ruffindustries's Avatar
Default Dash board delete
Hey Guys, Looking for a little guidance. I'm currently in the process of designing my interiors on my XJ6. I'd like to eliminate all components that aren't a requirement for the car to run and function correctly that way I can do a aluminum dash panel with as little buttons and switches as possible. Its also a vehicle that only runs in the summer so heater vents, switches, radio, I have a fuel cell so fuel tank button, everything.
Knowing nothing about wiring, whats the first step in determining what needs to stay. Any advice on the topic would be great. Anything on bar minimum wiring, what people have done in the past. Stereo is completely removed, battery is relocated to the trunk, considering a digital dash. ECU upgrade?
Old Feb 6, 2022 | 06:47 PM
lickahotskillet's Avatar
Default what wiring to keep
Inventory the circuits that you will be keeping. Are you going to use an aftermarket harness? Is the car going to be "street legal?" Lights, turn signals, 4 way flashers, horn? Aftermarket Gauges?
Old Feb 6, 2022 | 07:39 PM
I just reviewed some of your other posts. It looks like you are well on your way.
Old Feb 7, 2022 | 08:54 AM
Street legal yes. Is there a harness you suggest? I didn't necessarily think of replacing the harness but if it makes this easier I would yes. I also plan on doing an LS swap down the road. The Holley digital dash can be wired as a stand alone and then also be a plug and play for the LS swap.
Old Feb 7, 2022 | 08:55 AM
Defiantly learning as I go. The knowledge available here with you guys is endless! Greatly appreciated.
Old Feb 7, 2022 | 04:28 PM
Default Aftermarket Harness
No recommendations here! I am using a Painless Pro Street 21 circuit on my MK2. What you discover is you begin marrying brands of harness, switches, gauges, and OEM, etc. It's a GM based, left hand fuse block harness. And of course my fuse panel is on the right. Pictures under my main post under the MK2's.
Old Jun 11, 2022 | 10:42 AM
What are your thoughts on the painless set up? Would it make sense to start with something like that and wire as I go?
Old Jun 12, 2022 | 05:47 PM
Reviewed you post. If you are gutting wiring, be sure of what you want to keep and marry to an aftermarket harness. I thought the painless would be simple. Nothing about wiring is simple. Also look at Ron Francis. Order their catalogue. It's easier to follow then catalogue, then reference their website.
Painless web side is good as are their pdf's.
Not sure if I am answering your question.
Stanners
Jul 11, 2016 08:37 PM
asaphelps
Mar 9, 2016 09:06 PM
wardhill
Jun 2, 2014 07:02 AM
Simprof
Jun 13, 2011 12:22 PM
