dash board kits
Old Jul 24, 2014 | 04:03 AM
oldjagowner's Avatar
Smile dash board kits
hello to all jaguar owners does any one know if its possible to purchase a complete dash refurbishment kit for a ser3 xj6 sov. 1985 on line I liveinaustralia and bit hard to source from this end thanks
Old Jul 24, 2014 | 10:47 AM
Darrenmb's Avatar
Veteran: Navy
If by chance you are talking about the stick on plastic wood stuff. I would suggest not doing it. I did it to mine and although it looked good from 20 ft. Up close i did not like it at all! This is of course just a personal preference, i ended up buying a vdp dash on ebay and sanding it and refinishing it myself. There are vendors out there that are selling refurbished dashboards, but i found them a wee bit expensive. I have photos available if you need to see the plastic stick on wood.
Darren
Old Jul 24, 2014 | 11:35 PM
gmachinz's Avatar
I've designed a mockup from the original dash insert-Ill be test fitting it this weekend and then having a final piece cut from a cherrywood hardboard piece which will be sealed on both sides and polyurethane coated with a UV inhibitor. Here's a pic of the mockup made from 3/8" hardboard cut on a CNC wood router table. I've installed AutoMeter Pro Comp gauges to replace the OEM ones. If you would like a prefinished ready to go dash trim, PM me and I can work something out with you. It took about 5 hours just to set up the CAD drawing to prepare a file from which this board could be cut from.
This trim houses 3&3/8" speedo and tach along with 2&1/8" gauges. I stock Autometer gauges as well. Here's a pic of my work on this so far....
Attached Thumbnails dash board kits-img_20140724_221247_010.jpg   dash board kits-img_20140724_190704.jpg
Old Jul 25, 2014 | 06:09 AM
Default dash board renewall
hi gmachinz when u have finished the project would you post some picts of them also would I be able to reverse the wood work to fit a rhdrive car
Old Jul 25, 2014 | 08:35 AM
Roger Mabry's Avatar
Default Get new dash wood
I have purchased two sets from CG Woodcraft, Gary is very helpful and they
fit fine with all the hidden holes drilled properly... your choice of finishes...
Old Jul 25, 2014 | 06:50 PM
gmachinz's Avatar
If you need it RH drive, the file can simply be switched so yes...not a problem. I am in the middle of assembling a wiring harness designed for the AutoMeter gauges. Everything I've labelled and have made it plug n play. While this is for aftermarket gauges, I also have a CAD file for the stock setup with indicator light provisions as well. I did not research where to get these inserts but since I handle every aspect of custom builds including electrical harnesses I like to integrate as many things as I can to make it easy.
Old Jul 26, 2014 | 08:08 AM
gmachinz's Avatar
I also thought about refinishing one in carbon fiber and converting the tan over to black interior just because it would be a killer look! I may have to look for my own Jaguar to build after I finish my dads....this has been a really fun project so far-a lot different from what I'm used to building but I bring my own things to it so it keeps it interesting.
duecedriver
Dec 25, 2015 11:47 AM
dstary
Sep 19, 2015 09:47 AM
vincent661983
Sep 10, 2015 05:52 PM
1964Daimler
Sep 9, 2015 11:28 AM
arnoldmilk
Sep 3, 2015 07:42 PM
