Dashboard - interchanging
Old Oct 27, 2019 | 07:28 PM
Crackerbuzz's Avatar
Default Dashboard - interchanging
Hey all,
I have been told the timber dashboard panel from a SII will fit the SIII and vice versa
Before I shell out cash, has anybody done this?
Craig
Old Oct 27, 2019 | 08:10 PM
Yellow series3's Avatar
I would ask David at everydayxj.com. He has seen them both out of the car. May even have them sitting around to compare.
Old Oct 27, 2019 | 08:41 PM
Doug's Avatar
Never tried it but my understanding is the two will fit interchangeably but are slightly different with respect to the central warning light cluster between the tach and speedo. The cluster is slightly different therefore the wood would be cut differently in that area
Worth double checking
Old Oct 27, 2019 | 08:47 PM
Doug's Avatar
The difference is apparent in these pictures
Old Oct 27, 2019 | 09:37 PM
Thanks Doug... Will check it a bit more...
Old Oct 28, 2019 | 06:48 AM
yachtmanbuttson's Avatar
I removed my SII dash and installed a SIII one. And to Doug's point, yes the center warning cluster is different. I had to acquire a SIII one to complete the project. Also note the catalyst warning light (and subsequent hole) is on the SIII dash also. As my SII doesn't have a catalytic convertor, I used that hole for a electric fan is ON led light. As I don't have a mechanical fan anymore, I thought it important to me to know when the twin electric fans were on. And... the SIII dash has the stickers under the side vents.
SIII Dash I bought and installed.
Old Oct 28, 2019 | 06:50 AM
Also note the SII warning light cluster has a silver paint job around the edge to match the rest of the gauges and the SIII one does not. No big deal to get a small bottle of silver modeling paint and paint it though.
Old Oct 28, 2019 | 08:37 AM
Jose's Avatar
or you can get Chrome Nail Polish, a lot nicer than silver paint.
Old Oct 28, 2019 | 08:43 AM
Jose - it probably is, but then I'll assume you have to then paint all the other gauges to match. But... Maybe I'll put that on my wish list when I'm done with everything else. (Like I'll ever be done!).
Old Oct 28, 2019 | 09:34 AM
If it helps, here is a photo of an 87 SIII dashboard with the warning light cover removed.
cdma
Apr 25, 2018 10:08 PM
paulyling
Feb 7, 2017 05:36 PM
Wolfman01869
Feb 22, 2015 03:49 AM
michaelz
Feb 2, 2014 09:57 PM
sidescrollin
Apr 12, 2012 10:50 PM
