delayed 2-3 shift
Old Dec 28, 2014 | 08:00 AM
Darrenmb's Avatar
Veteran: Navy
Default delayed 2-3 shift
Hi folks, i hope evryone had a fantastic christmas! My car is all done finally! She even got her first coat of wax yesterday! Took her for a nice long drive and found i have a delay in the 2-3 upshift, i had replaced the downshift cable while car was laid up, and set it all by the book making sure that it was at top of cam lobe on full throttle, i do not have a pressure gauge to do the othet test. Is this where my problem lies? Or should i look elswhere???
Last edited by Darrenmb; Dec 28, 2014 at 08:01 AM. Reason: please forgive spelling errors. im using my phone and have large thumbs
Old Dec 28, 2014 | 09:09 AM
Does it merely take longer than usual to shift while engine speed remains steady, or does the engine speed up while it's deciding to shift?
Old Dec 28, 2014 | 09:10 AM
ronbros's Avatar
do you have manual or auto transmission?
gotta start someplace.
Old Dec 28, 2014 | 12:08 PM
Darrenmb's Avatar
Veteran: Navy
its an auto, no slipping, just stays in 2nd longer than it used to
Old Dec 28, 2014 | 05:30 PM
Series1fan's Avatar
Hi Darren, can you go through the shifts for us: What rpm are you at for 2nd and 3rd? And it's a BW 12?
Old Dec 28, 2014 | 11:36 PM
Doug's Avatar
Yes, the detent or TV (throttle valve) cable could be causing this.
You really *should* use a pressure gauge for adjustments but few of us have them....and it appears that minor adjustments seldom take the pressures into the danger zone.
So.....
Try slackening the cable a couple 'flats' of the nut and see if anything changes...and maybe a couple ore flats after that if needed. Not sure If I'd be comfortable with much more than that.
Old Dec 28, 2014 | 11:37 PM
Doug's Avatar
Should be a BW66
Old Dec 29, 2014 | 01:25 PM
Darrenmb's Avatar
Veteran: Navy
thanks Doug, i will give it a shot, the reason i changed teh cable was that when trans was rebuilt about 3 years ago (keep in mind car was pulled off road pretty much right after) the trans shop did a bodge job on the cable! they had replaced it with one that was longer and had just wrapped the new one around a bolt to take up the excess length! Of course being as it was 3 years ago im out of warranty anyways, just don't wanna go back there!!!
And yes its a bw 66, 2-3 shift is happening close to 3k even when not pushing car hard! unless i let foot off for a couple of seconds then it will shift up lower!
Old Dec 29, 2014 | 05:12 PM
Darrenmb's Avatar
Veteran: Navy
I just came back from a test drive after numerous adjustments totaling almost 3/8 " she seems to be doing much better!!! now just gotta find that damned machine gun sound, its not the trans mount, its all new! no shiny spots that i can see on any rotating parts either!! I wonder when the local car club is having its next rack day!!! im sure i could find it in just a couple of minutes if i were able to actually move around under there!!! It sucks having a santa belly!!
hkmcmast
Nov 29, 2015 06:56 AM
danke
Oct 3, 2015 09:31 PM
hughey
Oct 2, 2015 05:17 AM
dansxj6
Sep 28, 2015 08:02 AM
