Diagnosing A/C Main Relay
Old Jun 25, 2024 | 04:56 PM
Yellow series3's Avatar
Default Diagnosing A/C Main Relay
My a/c system is cutting out intermittently. It will work fine for 10 minutes and then go completely dead in all settings. Then a while later it will start working again. Car is 1979 XJ6 SIII. I've read all the relevant threads here and studied the S-57 wiring diagrams. Before I start tearing the dash apart to look for loose connections I started by checking all 4 fuses. Now I am trying to see if the main relay is working correctly. Here is what I've done so far:
  • Brown/white wire in the middle has 12v
  • Black wire in lower middle right has good ground
  • Jumping 12v to the Green/slate wire runs the fans
  • Brown/white in lower right has 12v with key off as it should.
  • All terminals are tight with no burn evidence or corrosion.
I know the resister pack adds resistance in 3 steps to control fan speed at the 3 terminals marked “resister pack” but I have not found any guidance as to testing them. So here is the question: any other checks I can do or should I move on to the mode selection switch? Thanks for your help.
Old Jul 17, 2024 | 10:29 AM
Well, I'm a little further down the road. After a lot of testing, studying wiring diagrams and talking to Gary at Jag-Aire I figured out the problem is my mode control switch. I made a little video that I hope will help someone in the future. Here is the
adenshillito
Jul 24, 2021 11:15 PM
Montana Dan
Jul 1, 2018 05:34 PM
here2for
Apr 22, 2017 05:15 PM
George M.
Jun 14, 2014 07:41 PM
superjeep
Oct 5, 2011 07:51 AM
