diff oil
Old Nov 3, 2010 | 01:10 PM
Doug's Avatar
Originally Posted by chalkie28
hello im stuck at the moment my 1969 xj6 needs some rear diff oil im wandering what spec oil it is and how can i get it thank u
Nothing exotic needed. Ordinary 80w/90 weight gear oil will be fine. Shell, Valvoline, Esso, whatever.
If the vehicle history is unknown you might wanna drain whatever's left in the diff and install all new. Make sure you can remove the filler plug before draining, though :-)
Old Nov 5, 2010 | 10:52 PM
DrDodge's Avatar
Hey Doug,
Do the later cars (in my case an early SIII) use the same viscosity?
Thanks!
Jeff
Old Nov 6, 2010 | 01:29 AM
Doug's Avatar
Yup. same stuff. You can use 80/90 or 75/90. Whichever is on sale works for me.
Old Nov 6, 2010 | 04:33 PM
Christian 96 XJR's Avatar
Chevron Delo ESI 80W-90 is one of the best (if not the best) regular, non-synthetic gear oils. It has a lot of approvals from heavy duty truck manufacturers for extended drain (up to 500,000 miles in those applications).
It's a step up from regular GL-5 80W-90 gear oils.
Old Nov 27, 2010 | 12:55 AM
DrDodge's Avatar
Doug,
You don't happen to know the capacity for a drain and refill?
Thanks!
Jeff
Old Nov 27, 2010 | 01:03 AM
Doug's Avatar
About 2.25 quarts as I recall
kthrash
Feb 25, 2019 10:20 AM
JCam
Oct 23, 2016 08:27 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
SeanU
US Northeast
Sep 20, 2015 12:46 PM
