Differential fluid
Old Feb 11, 2023 | 07:49 PM
1977XJ5.3's Avatar
Default Differential fluid
What is everyone using in place of the old castol hypoy LS? Do the SII and SIII XJ12 use the same fluid? Thanks.
Old Feb 11, 2023 | 09:03 PM
Doug's Avatar
I use whatever 80/90 gear oil is on sale that day, GL4 or GL5. Valvoline, Shell, whatever. Nothing exotic required
Add some limited slip additive if the gear oil you buy doesn't specify "For Limited Slip Differentials" or similar
Old Feb 11, 2023 | 09:14 PM
Jagboi64's Avatar
GL4 is specified for manual transmissions with yellow metals ( usually the brass syncro rings) and GL5 has the additives for limited slip.
As far as I know all V12's have limited slip and it was optional for certain markets on 6 cylinder cars. For example, in Canada an XJ6 will not have limited slip, while a Sovereign will.
Old Feb 12, 2023 | 06:33 AM
iramphal's Avatar
Question
So, Jagboi, are you saying that my Canadian 1984 XJ6 Sovereign has an LSD?
Old Feb 12, 2023 | 11:09 AM
Jagboi64's Avatar
It should have, that was standard on Canadian Sovereigns.
yidal8
Feb 28, 2022 02:53 PM
Bigvettefreak
Dec 8, 2011 02:32 PM
turbo68
Mar 25, 2011 12:01 AM
ibateman
Jan 13, 2009 09:49 PM
Wild Bill
Oct 12, 2008 09:54 AM
