does an "o" ring go here?
Old Jul 10, 2021 | 08:53 AM
retroren's Avatar
Default does an "o" ring go here?
i installed the expansion valve THEN realized i may have neglected inserting an o ring on the inside wall of the valve that is connected to the firewall. i think i need to disassemble and insert an o ring. am i correct?
Old Jul 10, 2021 | 08:55 AM
retroren's Avatar
fyi: i am clear on all other connections for this part. just need clarification on the firewall connection. thanks
Old Jul 10, 2021 | 09:31 AM
Doug's Avatar
It's been a few years. Foggy memory. But I'm 99% sure you need an o-ring there. I'm hard-pressed to remember any a/c connection on any car that doesn't use an o-ring.
Maybe there are a few that are simply taper-seat fittings?
Others will chime in
Old Jul 10, 2021 | 10:32 AM
motorcarman's Avatar
The series I XJ6 used taper and compression fittings but later cars all use the 'O'rings in the A/C system.
Old Jul 10, 2021 | 07:55 PM
retroren's Avatar
a big thank you for your quick response.. now i get to use the custom tool i made for the firewall nut. i'll post a picture of it.
Old Jul 10, 2021 | 08:41 PM
I use a 1 1/16" 'crow-foot' wrench/socket and a LONG brace to support the fitting.
If the 'nut' does not move, I have a LOOOONG air chisel to break it loose with a notch on a flat.
The smaller fitting can also be removed with less force (and 'crow-foot') so it usually survives.
I have NOT damaged an EVAP core in 40 years.
I have had to replace them when they were 'twisted-off' by overly anxious mechanics. (DASH OUT)
Go slow and use penetrating oil.
Old Jul 11, 2021 | 11:04 AM
Larry Louton's Avatar
Hello, If you didn't take a O ring out maybe it is still on the pipe, If you haven't all ready, look in with a inspection mirror and a flashlight. to confirm this. Use small bent pick to withdraw. use old one to size new one.
Thank you.
Larry Louton
foxbottom
Aug 28, 2023 04:03 PM
Higgins
Jan 25, 2021 05:23 AM
Daim
Jul 30, 2019 03:18 PM
