Engine compatibility
I have a 81 xj6 . I want to take gearbox and engine out of a 83 xj6. Are there any changes that will prevent a straight swap over. Both are 4.2's
Fundamentally this wouldn't be a problem.
In 1982-83 changes were made to the cooling system and perhaps some other sub-systems that escape my memory at the moment but nothing major. Anything from the 'early' design could be removed and reinstalled on the later design engine.
if the 83 has a different cooling system and injection arrangement you can swap the inlet manifolds to suit, i know the inlet manifold on my 86 is different to the one on my 81 spare engine, the easy tell is the fuel rail size[larger on the later]
OkieTim
Sep 8, 2015 04:48 PM
